Question about Dell Dimension 3100 PC Desktop
My speakers work but there is no sound coming out of my computer
  • YourZEN
    YourZEN May 11, 2010
    Check the hardware for the sound card in the hardware manager. Look for updating the driver of the sound card.
    Sniper:
  • 77 Answers
Try rolling back your sound drivers (control panel, system, hardware, device manager, sound and audio devices, right click your sound hardware, properties, drivers), if this fixes the issue go to microsoft update, run the 'custom' scan...it should show you an update to your sound card/hardware, click the little "+" sign beside the update and click the little "Do not show this update again" checkbox. This will prevent automatic updates from "fixing" your drivers. Occasionally Microsoft sends out updates that are incompatible with a particular machines' setup.
Hope it helps.
Posted on Oct 18, 2009
  • 3 Answers
Where to begin troublshooting this, how about the beginning!
1. Check power on to speakers and all connections secure
2. Check which sound port they are pluuged into (should be green)
2a. Check sound properties in Control panel if no speaker icon on taskbar. Is the Volume control turned all the way down on your computer OR the speaker control or Muted? Unmute and turn sound up :)
3. Check Device Manager Sound, video and game controllers for your soundcard entry. If any items have yellow question marks, right-click and update drivers accepting all defaults. If any have red X's select Enable.
4. If no drivers are downloaded Run Microsft Update
5. No driver updates, go to your install disc, they should be there or you computer's support site and download the latest drivers for your system and follow site instructuions to install.
6. Check cables, plug input into mp3 player headphones port and check for sound.
If none of these solutions work if attempted in this order and you get sound from other inputs you have either a damaged speaker sound port on your computer or sound card. If you have a headphone port on the front of your computer, plug your speaker input cable to that port and repeat. I have seen bad speaker out ports on the back before due to misuse ususally caused when the computer is jammed into a cobby hole in these tiny computer desks and using the front port worked fine.
If none of these work you have either a bad onboard sound chip or sound card.
Posted on Oct 06, 2009
    Guru:
  • 830 Answers
Download and install audio driver free from Dell.com:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_3100&os=WW1&osl=en&catid=&impid=
Reboot computer and your good to go!
Posted on Oct 03, 2009
My speakers are plugged in correctly but no sound is coming out of the speakers
Do you get sound out of the computer speaker (inside computer)? If not, go to device Manager and see if the sound drivers are loaded. If not, you will have to find the drivers and load them. If you sound from the computer speaker, then I would try the speakers on another computer that you know works with external speakers to ensure the speakers are good.
Apr 01, 2011 | Harman Kardon HK206 Computer Speakers
No sound from speakers
Test the speakers by plugging them into something you know has a jack that works, like an iPod or MP3 Player. If the speakers work on that then the issue is with your computer. If it does not work it may be the speakers. Make sure all the plugs are securely connected for both power and sound. If the speakers do work make sure that the computer isn't muted. If the sound is on try using a different port like the headphone port. See if sound comes out of the speakers then. If it still isn't working you may want to try uninstalling the sound drivers and downloading the latest ones to install.
Mar 29, 2011 | Dell A215 Computer Speakers
I just created my own pc. i decided to go against getting a sound card. My sound works coming from the mobo. I hear the music from my display moniter speakers. When i connect my headphones to the front...
You need to change the sound profile from 2 speaker system to surround sound. You will find this in the control panel area program.
Hope this helps.
Thanks
Jason
Oct 25, 2010 | Logitech X-530 Computer Speakers
No sound comes out of the speakers. They previously worked fine prior to moving
If you have a soundblaster or onboard sound card, be sure that the cord coming from the speakers to the computer is plugged into the green inlet in the back, not the black one. If you plugged into the black inlet there will be no sound from the speakers.
Sep 24, 2010 | Boston Acoustics BA745 Computer Speakers
Sound wont come out speakers
Not to sound like I am taking the pi**, but arae you sure you plugged into earphone/audio out????
Try using a pair of earphones you know work and if you get sound then the speakers could be faulty.
Nov 06, 2009 | Juster Computer Speakers
No sound coming out of speakers green light on speakers is on
The BA 735 Speakers I have are purely digital and will only work if your soundcard has a digital output, will not work through the normal analogue green socket .
Jun 19, 2009 | Boston Acoustics BA735 Computer Speakers
Only 2 speakers working
on your computer if you go to
  • start
  • control panel
  • sound and audio devices
  • click on change the speaker settings
  • click advance in speaker settings
  • and change it to 5.1 suround sound
Apr 11, 2009 | Audio Players & Recorders
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
Dell Dimension 3100 PC Desktop Logo
916 people viewed this question
Alun Cox
