Question about Dell Latitude D505 Notebook
Hello today I had an white vertical line in the center of my PC screen Gateway E2500s series would not shut down from the tower so IV turned it off with the surge and waited a few them turned it back on now it's working again just fine. Can you tell me if it's OK or is something going wrong with the tower or screen thanks lee
  • jovanni cabanag
    jovanni cabanag May 11, 2010
    im consfused with your post. The topic is Dell Latitude D505 PC Notebook but the laptop your having an issueis Gateway E2500s series. Please make this clear.
    Novelist:
  • 225 Answers
You mention in your post to branded laptops. You can try to check if the problem is from the LCD or from the Video card. Connect your laptop to an external monitor and check if the white vertical line appears, if yes replace motherboard if video card is integrated, if expansion then replace video card alone. If no lines from the external monitor then laptop LCD has the problem.
Posted on Oct 04, 2009
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Averatec 4100 series white line on screen
Okay go to: Flexcode.org/lcd.html
Once there select toggle full screen, then try 2nd method. Click on ( go full screen now) Let this run for 30mins. to an hour. Keep on full screen.
Your labtop screen pixel can be stuck on that color. This should help it go back to normal. If not, I have another method. Try this one out first.
*NOTE* Do not try the Pressure Method or Tapping Method.
Jan 31, 2009 | Computers & Internet
Vertical lines down center of Plasma TV
Because of the complexity of these sets, the fault can be much more than just a bad IC. These sets are serviced at the board level. After changing the board, calibration is done as necessary.
The fault may be in the matrix power driver output area, or in the plasma screen back-plane layer itself. This has to be determined by the process of elimination.
I can tell you in advance that this will not be a low cost repair.
Jerry G.
Jan 10, 2009 | Philips Magnavox 42MF521D/37 Television
Wide vertical lines on screen
Hello there!
First things First
1) If you can or have another monitor try and see if the problem persist.
2) RMS the monitor if you keep these problem in these particular monitor.
3) usually these, problems, its cause by a bad capacitor in the monitor motherboard, or resistor.
4) it is best to return the monitor.
Carl
Apr 25, 2017 | Gateway FPD1775W Monitor
Blank screen or vertical colored lines on monitor
sounds like a graphics card failing
is it on board graphics ?
if so try a graphics card in there see if that helps it
also if you could borrow a monitor and see if that helps
its either one or the other and is a process of elimination
Mar 24, 2008 | Gateway Profile 4 All In One (MPN...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Dell Latitude D505 Notebook Logo
190 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
