SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll
need to keep running it untill it runs clear and it uses alot of your
ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
SOURCE: will not print yellow,all yellow will be pink!
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side.
choose maintenance under general links and choose printhead cleaning. if this does not solve the issue,
call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
SOURCE: My Kodak ESP5 AiO printer has its print head stuck at its right.
Dear Sir/Ma'am,
• To resolve this issue remove the cartridges and then the printhead (Upon removing the cartridges look into the slot where the black cartridge fitted into. On the vertical wall at the back you will see two small contact points. Place your finger above those points on the black plastic and run your finger towards the top of the printhead. You will feel a little button and by pressing it , it will release the printhead.)
• Remove power
• Please now check for any objects or paper that might be obstructing the movement of the printer carriage - if any are found please remove them
• Wait 5-7 minutes
• Reinsert power
• Reinsert printhead (When inserting the Printhead please ensure that you hear it click into place)
• Then re-insert cartridges, black first then colour.Please also ensure that you hear them clip into place
Regards,
CViveiros
SOURCE: I recently purchased a Kodak esp5 all in one. I
I had this exact same problem. After weeks of frustration, and uninstalling, updating and reinstalling the software more times than I can count, I discovered the solution was to make sure the USB cable was connected directly to the computer, rather than through the USB hub I had been using. Once I plugged it into the back of the computer the scanner finally started working. Hope this helps!
SOURCE: Kodak ESP5 Error Code 3802 and will not print
Issue is with printhead
visit www.kodak.com/go/itg
Select all-in-one printer
Select image quality > missing color > follow the steps to order a free printhead
Else
call 18004216699
