Question about Gateway 802.11g Wireless DSL/Cable Router [ Belkin F5D7230-4 Wireless ] (108995)
How do i put a password on my router? I no longer have the installation discs that came with it.
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
I too have a Dir 615. My HP died, now I have a new toshiba but cannot remember my password. My iPhone picks it up no prob but I logged it on when I first got the router. Like I say can't remember...
On the back of the router, press and hold the reset button for about 5 seconds.
Then plug a computer into the router and setup the router again, hopefully with a password you'll remember this time.
Dec 25, 2011 | D-Link Computers & Internet
Cant find my security code and trying to set up Wii to internet
If it was installed by a cable company, check your documentation that came with your router that will be a handwritten note with the password. Or ask another member of your household if they know it. Or you must reset your router (there is a small pinhole in the back of the router, hold it down with a paper clip for 10-30 seconds until it restarts. Your internet will no longer have a password on it, however anyone with a computer will be able to access it. I would recommended putting a new password on it that you will remember.
Mar 20, 2011 | Nintendo Wii Console
Lost password for vgn fe770g. I need to reset pass word
Download windows password removal tool 3.0 and burn it on a disc then put it in the laptop that you want to remove the password and have the laptop set to boot from cd/dvd and follow the instructions it's only a short few steps. It's going to take you longer to put it on a disc than to get rid of the password.
Mar 08, 2011 | Sony VAIO VGN-FE770G Notebook
I have a Dlink N150 router. I have reset the router by pushing the reset button in the back and am now trying to reinstall it. I am using the installation disk and I get to the step 3 of 6 where I connect...
Be sure you have pressed the reset button and held it pressed for at least 10 seconds. A simple push and release only reboots the router (keeping the old settings). A full factory reset (10 seconds) will replace all settings in the router with the factory default (username and password as well).
Jan 02, 2011 | D-Link Wireless N 150 Home Router 4Port...
I need to secure my password on my router so our neighbors can't use our wireless internet
If your router isn't secure get one that is.Some routers are not secure.They rely on the user to secure the router's security codes.All routers come with a disc if it didn't it's a mickey mouse router.Install the disc again if you didn't do it before.Your PC should recognise it.Some operating systems don't recognise the router.Go to hardware in the control panel Where it says install a device click on it.Windows will check to see if a driver is available for your router.Go to the manufacturers website and download the driver for your particular router.IT will come up with boxes and you put in the model and serial number and it will search it's database for your driver.Good Luck.
Aug 07, 2010 | D-Link DIR-655 Wireless Router
Installation software true mobile 2300
hello.. u can setup ur router even there is no setup disc.. check first the default gateway of ur router by connecting your computer directly to the router using an ethernet cable.. to check the ip gateway, click on start, run and type cmd, it will give u a dos prompt, from there type ipconfig/all and check the default gateway,ex.. the default is 192.168.1.1, close the dos prompt and pull up the internet brower from the url.. type in 192.168.1.1 and it will ask the username and password.. u need to enter it, by default the username is admin and the password, just leave it blank, if didnt work try 1234.
Aug 04, 2009 | Dell TrueMobile 2300 Wireless Router...
I need to set up without installation disc. I have a belkin n1 router and can not find the install disc. Im back online but without security.Cant figure out how to get my password put back on the router.
you do not need the disk.
you can log in to belkin router by typing 192.168.2.1 and press Enter, in your internet explorer (in the address bar ),
click on "wireless" on the left, click submit without entering anything (for the password), and you can click on security. and u can setup the key from there. but best to call them and theywill help you. call them at this number 8777365771
Jun 18, 2009 | Belkin (F5D8231-4) Wireless Router...
I am trying to reload my disc for my Linksys WRT54 V5 router and it won't go past the password and everything I have tried it won't move on. How do I reset the whole system and put in a new password.
look on the back of the router there should be a reset button
i had this problem when i had a linksys router
i used there automatic installer
Jun 27, 2008 | Computers & Internet
Netgear router DG834GT
To do this you do not need the installation disk.
1. Click Start, Run, CMD, enter. Type 'ipconfig /all' and write down or remember the ip address for your default gateway.
2. open your browser and type http://192.168.1.1 (or whatever the ip address is for your default gateway.) hit enter.
3. In the username and password login screen type admin for both. If this doesn't work, try using admin for just the password, if no luck try again for just the username, until you are logged in.
4. Go to wireless settings, security, and find the part where you can set your wireless password. It is also a good idea to use wpa personal instead of wep, because it is a stronger encryption method.
Apr 15, 2008 | NetGear WGR614 Wireless Router
Gateway 802.11g Wireless DSL/Cable Router [ Belkin F5D7230-4 Wireless ] (108995) Logo
187 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
