Question about Epson Office Equipment & Supplies
I have a Epson Stylus CX4800 printer and I have been cleaning and lost the connection from printer to router where is the usb port located?
    President:
  • 2,666 Answers
There is no USB connection between Router and Printer
Posted on Oct 03, 2009
Hook it up to my laptop
There should be a port located at the back of the printer where you can run one end from the back of the printer to the USB port on your laptop. Once connected your laptop should recognize it as a new device and give you instructions from there. Hope this helps good luck!
Oct 18, 2014 | Epson Stylus CX4800 All-In-One InkJet...
Can't locate how to clean print heads on my Epson Stylus CX 4800
Hello, to clean click on start, then click on printer & faxes, then double click the icon Epson CX4800, until it opens. You will see the printing que. Click on printing preferences then select the maintenance tab.
See below., and hope it helps.
Good Luck :0) HERE ARE 2 DIAGRAMS.
Nov 06, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus cx4800. Question 1 - does it matter which USB port I use on the computer? I can't find the scanner software! Any ideas on the start up software download locations
Answer for Q1.No . When you first hook it up it does not matter which USB prot that you use. After it is installed it must stay on the same port. Q2. You can let Windows install the software and you can tell it where you put the driver. I have inclused the driver download link below. Make sure that the driver is for your version of windows ( If using the supplied disk ,make sure it specifies for your version).  If you need any further assistance , let us know.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&infoType=Overview
Feb 26, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Lost CD software to epson stylus CX4800
u can download the epson stylus cx4800 printer    from the link below..
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58606&prodoid=56291067&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=18&y=5
there u see many links for several softwares and drivers,choose the appropriate,,,,,,,
if this solution helped or not helped?  pls reply...
Jan 24, 2009 | Epson Stylus CX4800 All-In-One InkJet...
CX4800 ''communication error'' with MAC OS X
I had the same problem. I think it's about how much power the printer draws from the usb port. I would suggest the following:
Plug the printer directly into the back of your mac, not into the keyboard or front ports. These ports have the most power and so should give you a trouble free connection.
If this doesn't work (and this is what I ended up having to do). Get as short a usb cable as you can to link between the mac and the printer. I found longer leads constantly caused problems with this printer wherever I plugged it in. This fixed it for me. It means they have to live very closely together but at least I don't want to throw the printer out of the window anymore!
I'm not sure who the fault lies with, Apple for providing underpowered ports or Epson for demanding too much power from the usb (it's not like the the thing needs the mac to power it up!). Probably a bit of both.
Nov 19, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Lost manual for cx4800- how do you clean heads- images are banding
If you have a printer icon in the quick-start portion of the task bar (lower left corner of the screen), Mose over it and see if it's for the Epson 4800; if so, right click the icon and you'll see the maintennce services listed
Aug 18, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson stylus cx4800 printer
its the carriage jam..probably main board timing!
I have two printers here with same problem...the white plastic flag is jamming the carriage (therefore, carriage stall)...
its not the power supply..the white flag is popping out at the wrong time.
I am ordering a main board for one of the printers, to see if its a timing problem.
Jan 14, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson cx4800 and windows vista
The most likely causes are that you hooked the printer up prior to installing the software, the printer is defective, the USB hub has too many resource heavy things plugged into it, the usb port is corrupt, or the USB cable is defective. The first two are the most common causes.
Dec 03, 2007 | Epson Stylus CX4800 All-In-One InkJet...
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
