Question about Brother HL-2040 Laser Printer
RED LIGHT BROTHER 2040
I have a brother 2040 printer and the red light keeps coming on like i have a paper jam but there isnt one????????
  • 1 more comment
  • Dandrews2 Dec 26, 2007
    Have tried the by pass and nothing it actually just pulls it in about an inch then does jam, the paper is also with in the recomendations by the manufacture
    will try to clean rollers and see what happens
    thank you
  • Anonymous Dec 27, 2007
    The red light flashes, and when I try to print, it starts then stops before the paper has gone through. The print command erases immediately.
  • phillip457 Apr 09, 2008
    Same problem reported by others. No jam anywhere. Red light flashes. I poer cycle printer, goes to green then clicks and its back to red flashing light.
  • Brother Master
  • 1,113 Answers
Light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Posted on Dec 22, 2007
If all else fails, as it did for me, try removing the paper tray and feeding a sheet through the manual feed slot. On the printer I was working on, the paper would feed only about an inch and stop. I swapped toner/drum cartridge with another printer and that fixed it. I installed a new cartridge and the printer now works fine. Apparently, the cartridge was jammed and very hard to turn.
Hope this helps.
Posted on Apr 10, 2008
Brother HL-2040 paper light flashes red (and won't print) with plenty of paper in drawer
Check for a p[aper jam somewher in the route or at the single sheet feed entry
Mar 01, 2011 | Brother HL-2040 Laser Printer
Why does my 2040 Paper light (Red) keep flashing even though the paper tray is full and there is no paper jam?
There are several possibilities with too many to type here so, here is a link to the Brother troubleshooting page that gives several causes for the flashing red light. When you get to the page, scroll down until you see the "lashing "paper" light.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11
Hope this helps.
Aug 09, 2010 | Brother HL-2040 Laser Printer
Red error light is flashing on Brother HL-2040
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_006.html?reg=us&c=us&lang=en&prod=hl5240_all
Hope that helps,
Tiger720
Sep 13, 2009 | Brother HL-2040 Laser Printer
Same prob as sphil4988 11 Sep09 - RED PAPER LIGHT REMAINS ON EVEN IF NO PAPER JAM, THERE'S PAPER ON TRAY, UNIT IS CLEAN. THANKS FOR YOUR SUPPORT.
Check the Paper Sensor if it is in the Upright position or broken off it will keep asking for paper
check that sensor.
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Oct 23, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
765 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
