Question about Panasonic SA-HE100 Receiver
LOW IMP when trying to select A and B speakers together
LOW IMP apperas on screen all the time and ERROR appears when trying to select A and B speakers together
  • 75 Answers
Check the back of your speakers (both sets). If they are rated at less than 6 ohms, you cannot use both sets at the same time. (see page 12 of the manual)
Hope that helps!
Posted on Oct 04, 2009
Photocopy IR2230 error code 0001/0002
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Jun 02, 2014 | Canon imageRUNNER 2200
What is speaker A low imp . how to use speaker B.thank.
The Low Impedance setting is for when you have even one speaker with <8-ohms nominal impedance so you can use bot speaker pairs together. You still need to have an effective total (parallel) impedance of 4-ohms minimum or there may be problems like blowing up the amps.
Press and hold the SPEAKERS A or B button until LOW IMP lights or goes out, as required.
Press either button to toggle that speaker pair on or off.
It's in the manual page 14, 22 and 25.
Jul 03, 2011 | Technics SA-DX940
"Low Imp"
Low Impedance is not a suggestion, it is a WARNING. Your receiver is telling you it senses TOO LOW a load and it's trying to protect itself from damage.
Speakers A& B are running in parallel, so their combined impedance, X, is found by using the formula: 1/X = 1/A + 1/B.
In other words, two 8-ohm speakers in parallel would yield a 4-ohm load.
If your speakers are identical, try running them in series on one speaker output pair. That would keep the impedance safely high.
Feb 15, 2010 | Technics SA-AX540 Receiver
Disabling Automatic reboot during boot failure
press F8 when booting windows
then choose disable automatic restart on system failure
now it will appera a bllue screen with given windows error
Jul 19, 2009 | HP Pavilion dv6000z Notebook
Marantz 2220B with Sound Problem at Half volume
The most likely cause of this is some DC current working its way through the system. WIthout taking some measurements, it will be difficult to confirm this though. This should not be an expensive repair. Figure on $20 or so for parts (capacitors mostly).
Dan
Apr 12, 2009 | Marantz Audio Players & Recorders
Technics sa-ax730 won't play a&b speakers at same time.
This is similar to protect mode in that the amp has detected a short in the output and has shutdown to prevent damage. Without seeing the unit, I'm a bit hesatant to suggest repair tips. At this point, I would suggest you get a detailed estimate from a local shop. We should be able to guide you through the actual repair once the results are posted here.
Dan
Feb 04, 2009 | Technics SA-AX730 Receiver
My yamaha receiver shuts down when I turn it up.
If you have bare wire going into the receiver's output terminals, make sure a strand or two of wire is not touching the other terminal. That can short out the outputs, especially when you turn up the volume, which increases the voltage present at those terminals. That would cause the receiver to shut down as a saftey precaution.
Dec 13, 2008 | Yamaha HTR-5940 Receiver
Indesit1200 front loader not filling and flashing error code deno can anyone help
hi try these
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Aug 22, 2008 | Indesit Washing Machines
Panasonic SA-HE100 Receiver Logo
349 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
