Question about Euro-Pro Shark 80 - 7133
Top thread gets stuck around bobbin case
I am attempting to thread my machine but whenever I try to drawup the bobbin thread, the needle thread gets stuck around the bobbin case and won't come back up. My machine then becomes jammed. What am I doing wrong?
  • 74 Answers
You might have a bent needle
Posted on Oct 03, 2009
I have a necchi 4825 machine and the needle dthread is getting caught on the bobbin case as it goes around , why would this happen
One reason would be the holder that pushes against the bobbin is too tightly pushing against the bobbin. If it is much too tight it won't allow the thread to go past that point and get stuck. Another reason would be the bobbin case has a small cut on it. This must be smooth all the way around since the thread has to ride on it. The tension on the bobbin case should also be checked. If it is too tight it won't be able to extend the thread from the upper thread.
Nov 29, 2017 | Sewing Machines
I was attempting to pick up the bobbing thread, before sewing. The needle is now stuck in the down position and the handwheel is unresponsive but the motor is whirring when foot pedal is depressed.
Do not press the foot pedal. Continuing to run the motor when the machine cannot work properly could irreparably damage the motor. Unplug your machine. Cut the top thread at the needle, open the bobbin area and try to remove the bobbin case. You may have to patiently snip tangled threads, but eventually you should be able to get the bobbin case out. Once that happens, the needle will most likely be free.
Jun 22, 2017 | Sewing Machines
After cleaning the hook system which for which a problem was indicated., it still wouldn't work.
1. Clean the hook area again. Put one drop of oil on the race that the bobbin case rides on.
2. Make sure the holder on the bobbin case area is held secure while it is turning. It will need to be adjusted if the bobbin case wants to fall off of the race or has a lot of room when you move the handwheel back and forth. Test this by turning the hand wheel back and forth.
3. Once this is finished thread the machine through a new needle. a. Place the tension on four.
b. Now, turn the hand wheel towards you and hold the thread in back of the needle.
4. While doing this watch to see if the bobbin thread is pulled by the hook around the needle thread without getting stuck. (Needle now in rising motion still under plate.)
**If the bobbin thread cannot be pulled above the plate try to increase the top tension a small amount.
**If it still can't be pulled above the plate then loosen the bobbin a bit.
This may take a little while to get it right. Always, try to adjust from the top tension first.
Feb 15, 2016 | Sewing Machines
Breaking cotton on top and bobbin
Try loosening the tension for that bobbin
Dec 15, 2015 | Sewing Machines
I just brought home a Juki 8700. The needle went down and now I can't get it basck up. There is thread stuck in the bobbin. How do I get the bobbin casing off
Cut the thread above the needle eye and rock the handwheel back and forth sharply to cut the thread with the sewing hook. If that doesn't work pretty promptly, undo the needle clamp and turn the handwheel, which should raise the needle bar. Then get into the bobbin case area and try to remove the bobbin case, cutting any threads you can. Keep rocking the handwheel and trying to pull out the needle (pliers help!), and eventually everything will loosen up.
Next, clean and lubricate the area under the needle plate and the shuttle, and reassemble. Put in a brand new needle, right way around and fully up in the machine. Load the bobbin case with a well-wound bobbin, and rethread the top of the machine and you should be good to go.
Jan 28, 2014 | Juki DDL-8700
Needle is getting stuck on the bobbin case
That usually means there is a problem with the threading. If the thread is pulled through the wrong side of the needle, is wrapped around the top wheels wrong, or the bobbin is threaded wrong, this will usually cause it to jam up by the bobbin. i would suggest re-threading your machine, or if that doesn't work, contacting the problem hotline.
Oct 15, 2009 | Brother CS-100-T Computerized Sewing...
Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Apr 30, 2008 | Brother PE-150V Computerized Sewing...
Euro-Pro Shark 80 - 7133 Logo
534 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
