Question about Sony Ericsson W550i Cellular Phone
Pivot /swivel screws
I need the screws that hold the front to the pivot plate as my daughter has lost them. Any suggestions please
  • santapod01 Dec 22, 2007
    Thanks for your help I will contact them after Christmas. Have a good one.
    Ian
    President:
  • 1,944 Answers
This is a good site for parts. Here they sell the pivot (not sure if they come with the screws though and here are T6 screws. You should ask them before buying...I am sure they know exactly what you need.
Posted on Dec 22, 2007
  • Damen Wong
    Damen Wong Dec 22, 2007
    Merry Christmas!
How can I buy a new antenna for model sony cfm-165tw
Many boombox antennas are attached by a small screw through the pivot point. This is usually a #1 Phillips screw. Some do not have a swiveling antenna; for these you have to remove the back of the case to get at the attachment screw. Keep the screw; it's guaranteed to fit when you attach the new antenna.
The hard part is finding a replacement. If you have the pivoting/swiveling antenna, the Radio Shack 28" Replacement Telescoping Antenna 270-1405 ($5.99 online) will probably work. You might even be able to use it for a non-pivoting antenna that telescopes into the inside of the case.
Jul 22, 2014 | Sony Boombox Am Fm Tv Weather Band...
Tub on Samsung dryer not turning
Sounds like you have either lost the belt, or it has come off the idler pulley. Depending on how handy you are will depend on if you can repair yourself or not. Only takes a phillips screwdriver, but you must remove the top first (after unplugging or throwing the breaker). There are two screws that hold the top on. Slide it back, then off. remove the three or 4 screws that holds the console off, pivot it toward you and unplug it, or swing it over the top. Next you have to remove the front, 3 or 4 screws at the top, two screws inside the door panel (at the 7 o clock and 5 o clock, or the two very bottom screws) and there might be a couple of locks on the very top that just need to be lifted with a screwdriver. Unplug the door switch wiring, and then pivot it towards you, then lift off the bottom hinges. You now can look to see if the belt is just off or broken. To replace, you have to remove the front bearing plate, which is right in front of you. Remove the lint screen, then take off the three screws that hold the air duct on, slide it out, then down to remove. 2 screws on either side hold it on, remove these, then lift the bearing ring up off the slotted parts of cabinet, then remove. You might have to remove the top plate to do this, but a lot of times you can do it without it. Slide the belt over the drum, then get the belt over the motor and idler pulley (hardest part of job sometimes lol). Installation is reversed, and will be pretty easy if you remember what came off. Only wires to worry about are the console wiring, the door switch wiring, and the moisture wiring at the bottom right of the bearing plate. All have quick disconnects, so should pose no problems. Good luck!!!
Nov 10, 2013 | Dryers
I have a 21 speed mountain bike. it was wrecked, and now my front gear derailer is not locking into position, it always returns to the first gear unless i hold it in gear. any quick fix solutions as i...
The answer is to tighten the shift handle. The resistance to movement is inside the actual shift knob - it may be worn (tightened again and again) until there is no take up. Usually, you can turn the screw that holds the shift handle on, to tighten it. The pivot screw holds a One Way Clutch to assist in selecting gears.
I suggest that you uncrew the shift screw and add a small peice of paper to the "stack" to increase total width. Then you can turn the screw (at the pivot point) to increase friction of the handle.
Jul 27, 2011 | Cycling
Is fixing the ultinator yourself an easy job
  1. Disconnect the negative battery cable.
  2. Remove the drive belt.
  3. If necessary, remove any splash shielding for easier access to the alternator.
For easiest access to the alternator assembly, first remove the splash shield mounting fasteners ...
... then swing it out of the way for access to the alternator assembly
View of the alternator electrical connections-(A) battery positive, (B) field terminals, (C) wire harness hold down, (D) ground terminal
  1. Tag and disengage the alternator wiring.
It may be necessary to remove the alternator and mounting bracket from the vehicle as an assembly.
  1. If equipped, remove the front alternator assembly mounting plate.
Remove the six nuts and bolts that secure the front mounting plate to the alternator assembly
Remove the front alternator assembly mounting plate from below the vehicle
Click to Enlarge
  1. Unfasten the alternator mounting and pivot bolts and remove the alternator.
  2. If installing the original alternator assembly, push out the pivot bushing as illustrated.
After removing the alternator assembly front mounting plate, remove the front engine-to-alternator bracket mounting stud
Remove the two alternator bracket-to-engine mounting bolts
Remove the alternator and mounting bracket assembly from the vehicle
If re-installing, the alternator has a pivot bushing on the pivot arm that should be pushed out before installation
Mount a C-clamp and 18mm socket on the alternator pivot bushing ...
... then compress the C-clamp until it pushes the alternator pivot bushing out
To install:
  1. Mount the alternator to the brackets with the nuts and bolts. Tighten the two mounting bolts and nuts to 40 ft. lbs. (54 Nm).
  2. If the alternator and mounting bracket were removed as an assembly, install the assembly into the vehicle.
  3. If removed, install the front mounting plate.
  4. Engage the alternator electrical connections.
  5. If removed, install the splash shield.
  6. install the drive belt and attach the negative battery cable.
  7. shinehutt_58.gifshinehutt_57.gifshinehutt_56.gifshinehutt_55.gifshinehutt_54.gifshinehutt_53.gifshinehutt_52.gifshinehutt_51.gif
the job is akward ive incl as much info you need to repair yourself
plz comment reply if need more info
Jan 20, 2011 | 1995 Jeep Grand Cherokee
G4 transmission does not engage going forward
The handle pivot is set too far back on it's slide. It will be necessary to remove the handle, switch plate, and upper motor shell to access the slide. Two large phillips screws hold the pivot assembly to the slide. The pivot must be loosened and moved ahead very slightly, while centering the slide in place.
Jan 13, 2011 | Kirby G4 Bagged Upright Vacuum
How do I remove the alternator on my 1997 Grand cherokee ??
Removal & Installation
Once the determination is made that the alternator is at fault, off vehicle testing can be used to determine the defective component inside the alternator.
See Figures 1 through 11
Fig. 1: For easiest access to the alternator assembly, first remove the splash shield mounting fasteners ...
Fig. 2: ... then swing it out of the way for access to the alternator assembly
Fig. 3: View of the alternator electrical connections-(A) battery positive, (B) field terminals, (C) wire harness hold down, (D) ground terminal
Fig. 4: Remove the six nuts and bolts that secure the front mounting plate to the alternator assembly
Fig. 5: Remove the front alternator assembly mounting plate from below the vehicle
Fig. 6: After removing the alternator assembly front mounting plate, remove the front engine-to-alternator bracket mounting stud
Fig. 7: Remove the two alternator bracket-to-engine mounting bolts
Fig. 8: Remove the alternator and mounting bracket assembly from the vehicle
Fig. 9: If re-installing, the alternator has a pivot bushing on the pivot arm that should be pushed out before installation
Fig. 10: Mount a C-clamp and 18mm socket on the alternator pivot bushing ...
Fig. 11: ... then compress the C-clamp until it pushes the alternator pivot bushing out
To install:
  6. Install the drive belt and attach the negative battery cable.
Also, other details can find in your Grand Cherokee Repair Manual.
Good luck (and remember rated this).
Mar 21, 2010 | 1997 Jeep Grand Cherokee
Have lanmower with peerless 6845-pg1 transmission. have lost most power. have replaced belt
By "lost power" do you mean slower travel speed? Assuming your mower doesn't have an adjustment pulley, meaning a pulley with a bolt through it you loosen and move to replace the belt and put back in place and tighten the bolt once the belts replaced. Some do and this is where you adjust the drive belt's tension. Otherwise, when you depress the clutch pedal, underneath is a pulley or pulleys mounted on moveable plate. The plate pivots one way to put slack in the belt to disengage and the other way to tighten/engage the belt. I've seen them not fully pivot which doesn't completely tighten the belt allowing belt slippage and slower speeds. Use a spray lube on the pivot point (avoid getting it on the belt) and on spots where the plate looks to have rubbed against. This should let the plate to fully pivot again which will allow the belt to completely tighten, eliminating slippage, thus producing faster travel speed.
Nov 15, 2009 | Garden
How to get the alternator out
Jeep Cherokee 1984-1998
Alternator - Removal & Installing
Fig. 1: For easiest access to the alternator assembly, first remove the splash shield mounting fasteners...
Fig. 2: ...then swing it out of the way for access to the alternator assembly
4. Tag and disengage the alternator wiring.
5. If equipped, remove the front alternator assembly mounting plate.
6.
7.
Fig. 10: Mount a C-clamp and 18mm socket on the alternator pivot bushing...
Fig. 11: ...then compress the C-clamp until it pushes the alternator pivot bushing out
To install:
8.Mount the alternator to the brackets with the nuts and bolts. Tighten the two mounting bolts and nuts to 40 ft. lbs. (54 Nm).
9.
10.
11. Engage the alternator electrical connections.
12.
13.
More details for testing and diagnostics you can revies:
- Section-8A-Electrical-95xj8a
- Section-8B-Battery-Starter-Generator-Service-95XJ8B
I hope help you whit this, good luck (remember rated this help).
Sep 16, 2009 | 1996 Jeep Cherokee
Black & Decker Pivot Plus Cordless Drill/Screwdriver AC Adaptor
extend the handle straight and all will be reavealed! Just in front of the triger inside the piviot point.
Mike
Nov 13, 2008 | Black & Decker Pivot Plus Cordless...
Maxxum 7000
The lithium button cell is only a memory backup for when the main power pack is off the camera. It allows the camera to retain the number of exposures, asa setting, etc. You problem may lie in the battery holder. The BH70 was prone to corrosion at the contacts and the pivot points where the part that holds the batteries to the side plate with the retaining screw. It is possible to remove the batteries from the holder, then carefully separate the two pieces by popping one end enough to allow the pivot pin to slide past the notch. Use a hard eraser to clean all of the metal points (pivot contacts and the springs and plate in the 4 cell holder.
Jan 26, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Sony Ericsson W550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
