I went to print a Christmas letter....I had a paper jam------
I took out 2 sheets of wrinkled-up paper.
Then,it said: "Take out the drum"---I did...one sheet behind the drum....
I put the drum (the cartridge)back in the printer.
Trouble:
The printer window said:
"Back cover open....Close the back cover".
All doors are shut! None are open.
Did you lock the back door
If it has a slotted knob in the center
turn it to the right till it latches
There may be a lever/switch in the door
area that not making contact or defective or
broken
1.Use proper stactic discharge procedures
2.Did you touch anything in the shaded area
noted in the manual
3.Check for broken or misaligned
plastic parts in the area of problematic
door
If you are sure you have
all the jammed paper out
try pulling the plug out
for about a minute and
plugging back in see if
it clears
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Dear Tech 8:
How do I lock the back door??
Everything looks closed............
Moten
Thanks for your effort to help.
However/////////////don't have a slotted knob to turn......
Moten
