Question about Kenmore Dryers
Hum but wont start
I have a Kenmore dryer, 110.87683110 that is probably 15 years old.
It will no longer start.
I checked the door switch. Light comes on when open and goes off when closed.
Power from the house is fine.
There is a slight hum when you push the start button but nothing happens. The drum will move if pushed from inside and the belts seem to have good tension.
I also checked (what I think is) the thermal fuse on the housing near the exaust. There is no resistance on the meter.
  • 71 Answers
The slight hum you are hearing is the start windings in the motor. This is a common problem in the kenmore dryers and there is nothing you could have done to keep it from happening. the part number on the motor is 279827 and price from sears is $105.99.
Posted on Oct 04, 2009
Will not spin
You have a bad motor. At 15 years old, best to put money towards new one. Most motors are over $150 plus home call and labor charge if you call in a service company and you would still end up with a 15 year old dryer.
Jul 08, 2015 | Dryers
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
KENMORE lIGHT
I am assuming that your light bulb is good?
If so, your problem is your door switch.
Lighted dryers have 3 connectors on their door switch.
Sometimes when the switch fails either the light wont come on, or the dryer wont start. Either way this is a door switch problem.
Mar 05, 2010 | Dryers
Wont start
It depends on how old, but if it's less than about 12 years old, it is probably either a thermal fuse, or the door switch.
Feb 13, 2010 | Kenmore Dryers
Stopped running. Can't start.
You probably have a clogged vent. If the moist air can't vent to outside your dry times would be much longer and the heat would get trapped in the dryer. This probably caused your thermal fuse to fail. Once that fails the dryer won't do anything. The good news is that it should be a fairly inexpensive repair.
Dec 09, 2009 | Dryers
G.E. electric dryer will not run, when you turn the switch to start it only hums. What could be the problem, it is only 3 years old. Thank you
First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be seperate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safteys that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Aug 27, 2009 | GE Dryers
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Dryers Logo
119 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
