Question about Maytag Washing Machines
Doesn't start Stopped working once the water was in the machine. Now it doesn't turn on.
    President:
  • 1,304 Answers
Lid switch
Posted on Oct 05, 2009
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
How to clean jura C5 grinder
How to access grinder itself? Where is it? My Jura C5 doesn't grind coffee beans at all. Firstly grinder has started with starnge noise and then stopped with alarm "no beans", now it doesn't start at all..
Mar 06, 2012 | Jura Capresso Impressa Coffee Makers &...
Hot water pours out, cold water trickles. This just started happening this week. Is there a pump that forces the water to move or is the problem more likely the hose is plugged? or is there another...
The dual water inlet valve cold side is just stopped up with sediment. There is a screen filter in the water hose where it connects to the water supply. Cut the water off and unscrew the hose and look in the end of it for the cone shaped filter and clean it out. If that doesn't fix the problem you may have to clean or replace the inlet valve which is at the other end of the hose. The hot water doesn't usually have a problem because any sediment has a chance to settle out in the hot water tank.
Jun 10, 2011 | Kenmore Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
