Question about Sennheiser PXC 250 Consumer Headphones
Replacement connector for Sennheiser PX 250 doesn't work...
The headphone connector jack in my Sennheiser PX 250 had a short in it. I cut off the end and am trying to replace it with a 24k gold plated stereo plug purchased from Radio Shack, but I can't get the connector to work. I've tried all connections possible of the 3 wires (green, red, and copper) and get no sound. Even when I try reconnecting the old jack that has the short, I no longer get any sound (I did before, just muffled and only 1 side).
So what happened when I cut off the plug? Is it not possible to replace the jack?
These are borrowed headphones from my brother, and I'd really like to fix them instead of replace them. ANY HELP IS APPRECIATED!!
    Sniper:
  • 61 Answers
The bare copper conductor wire is the screening/common earth to the two signal wires of green and red. The important connection is the copper wire which goes to the jack plug earth which is the section furthest from the tip. The other two are the left and right signal connections. If you get these the wrong way round you will just have to swap them over. Check if they are the right way round by using the balance control on your amplifier or whatever. Have you checked that the problem is not with the headphone amplifier within your equipment? Don't rely on OK sound from loudspeakers as the headphones may be fed from separate op-amp output chip. Try another pair of cheap and cheerful headphones to make sure.
Posted on Oct 04, 2009
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
No sound in right headphone, however if i hold down the wire in a certain position sound is restored. is this fixable?
Sounds like u have a bad wire, Its fixable depending on where the break is. If its near the plug end, u can head to ur nearest radio shack and get a replacement, however, if the break is in the leading headphone, though still fixable but requires a bit more tech savy. As long as u can operate a pair of wire cutters and a soldering iron, youll be good to go
May 23, 2011 | Sennheiser PX 200-II Headphones
My daughter bought new headphones in America two weeks ago but when she got home bad connection at jack making bad hearing sounds in one of the ears. When you play about with jack connection it improves...
Well, there are a few ways to solve this. The easy way would be either to call the manufacturer (At (860) 434-9190, more info here) and see if there is a warranty on the item. Second, you could just buy a new pair, which is probably not the best way. Third, you could actually splice a new jack onto the headphones with a little soldering skill. You'll need to: 1)Cut the ******** the end 2)Strip the wires off the jack (and the replacement jack) 3)Solder the wires together (Matching black to black, red to red, ground to ground, etc)
If you've never soldered before, see if you could get a friend to help. Here is a video tutorial of how to solder, if you wish to attempt this yourself.
May 03, 2011 | Sennheiser HD 201 Consumer Headphones
I am trying to replace the jack on my PX100's. I have a replacement jack and have worked out which colour wires to connect to the various pins. Problem is resin cored solder suitable for other electronic...
See my tip on headphones jack/cable problems. Also sometimes they put on a special coating on the wires. You have to scrape the wire or file it to remove it. Spit is also good at making the solder stick!
Aug 20, 2010 | Sennheiser PX 100 Consumer Headphones
Replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
May 14, 2009 | Sennheiser PX 100 Consumer Headphones
My jack plug lead got yanked and broke the wires inside the electronics unit. There are three screws to undo in order to get inside the electronics, one by the cable entry and two very small cross head scvrews in deep holes halfway along the unit. I cut the jack lead on the outside close to the cable entry and drilled out the hole through the cable guide and then poked the jack cable back through the hole into the electronic unit. I was able to solder the three leads to their respective pads. There are five solder pads next to the cable entry. With the cable entry at the top, the middle pad connects to the green cable, the rightmost pad connects to the red cable and the copper connects to a pad about 1 cm down from the rightmost connector. The technique was to tin the ends of the leads with solder before soldering them to the pads. I used a blob of glue from a glue gun to hold the cable in place inside the electronics unit. My plan B if the soldering was not possible was to take a jack plug and lead from an unused set of earpieces and use that lead in place of the original. It would have been much more difficult to replace the lead from the electronics unit to the headset.
Jan 03, 2008 | Sennheiser PXC 250 Consumer Headphones
Sennheiser PXC 250 Consumer Headphones Logo
1,138 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
