Question about Sewing Machines
Upper thread no longer picks up the bobbin thread I have already replaced a small plastic gear myself, but my Elna Supermatic still is doing the same thing - NOT picking up the bobbin thread- as before the part replacement that a local repairman said I needed.
  • Sewing Machines Master
  • 1,388 Answers
Check the timing of the needle to the hook. HERE is a guide to generic principles of Timing
Posted on Oct 04, 2009
  • Hassy
    Hassy Oct 05, 2011
    Thank you for your positive feedback much appreciated, glad to help. Please Use and Share this link with friends next time you need to ask ! http://www.wix.com/i08870/justask
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
Jan 09, 2014 | Elna Sewing Machines
The needle on my elna supermatic goes up and down under power but the bobbin retainer does not move at all. I can move it manually but not enough for the top thread to pick up the bobbin thread. I would...
It sounds as if something has either gotten out of alignment or is broken. Take your machine into a qualified sewing machine mechanic. Have him clean, oil and adjust... and look for issues. It is worth the $$$ to get it fixed properly.
Apr 14, 2013 | Sewing Machines
How do you put a bobbin in a elna so i can use it to sew
Drop in a full bobbin with the holes side upwards (I'm assuming this is a Swiss Elna sewing Machine horizontal bobbin design as you haven't given the model number).
Now, hold the thread tail with your right hand and pulll the thread clockwise towards you while holding the bobbin still with a finger from your left hand. Bring the thread tail around towards you until it goes into the little slot, then press downwards onto the thread tail close to the bobbin until you hear it click into the tension spring. Test by lifting the thread tail upwards, it should stay in tension and not come back out of the groove.
Now close the back slide cover over the bobbin leaving the bobbin thread tail visible out to the right.
Now manually turn the flywheel towards you while holding the top thread tail and take the needle down into the bobbin holder area and back to the top, pull the thread tail to bring the bobbin thread up to the top.
There is a threading up diagrams at www.sewusa.com http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
for the old Supermatic but the bobbin holder design is almost identical for all the subsequent models such as the SU, TSP, Supermatic or Air Electronics like the Stella, Carina or Jubilee, the above is the same for all.
Sep 19, 2011 | Elna Sewing Machines
On my elna supermatic 722010 sewing machine, the thread makes the bobbin pop out and the thread get tangled underneath. I have had it fixed twice, which is expensive. Should I just get rid of it and buy...
not unless you can find another swiss elna, like star series su. check bobbin in right way, holes on top to wind and load. you havent bought anothet type bobbin??? go to www.arizonaexpressionz.com and download a manual for supermatic. then read bobbin winding and threading carefully and rewinf bobbin and thread up again. make sure thread goes into tension spring all the way. bobbin should turn anticlockwise when yoou pull thread. also please brush clean bobbin holder area and check for any threads caught there. now a drop of quality clear machine oil in middle hole and gently run for 30secs to work in. do this every time you get your machine out. there are several oiling points shown in manual. oil them. these machines are quality but yours may need love tlc from a elna tech especially if it has not been serviced in a while. but a well maintained elna will out stitch a new plastic machine any day in my humble opinion. if you want to join yahoo group elna heirlooms, experts who service their own and share photos info manuals and love these vintage classics.
Jun 16, 2011 | Elna Sewing Machines
I was given an Elna Supermatic 722010 and am not sure how to wind the bobbin.
A link to a supermatic manual is here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Supermatic.pdf - I suggest you download this and print it out as this machine is over 50 years old now and manuals are scarce.
Disengage the clutch by holding the outside of the fly wheel and turning the inner knob of the wheel towards you.
You need to take the thread from the spool across to an eyelet on top left, then back to the bobbin winder, up through a hole in the top of the bobbin and hold the thread tail. Flick the bobbin across against the stopper. Now press the presser foot or knee control to start the motor. Hold the thread tail until youve got coverage across the bobbin enough to hold the start, then stop winding and cut the thread tail with scissors. Now continue winding but put the handle of your scissors on top of the thread spool to stop it bouncing and ensure your thread winds smoothly and under tension.
Watch the bobbin fill and give the thread a nudge to fill top and bottom as well as the middle evenly, you want a nice even wind. Fill to 3/4 and stop, flick bobbin back off the stopper, then cut the thread. Remember to re-engage the clutch by reversing the first step.
This is a lovely heirloom Elna machine - you need to thread the bobbin as the manual describes and get the thread into the tension spring. Please read the manual information on oiling too, this machine needs to be oiled on the red spot locations every time you use it according to the manual, use good quality clear sewing machine oil for this purpose.
Oct 21, 2009 | Elna 2007 Mechanical Sewing Machine
What bobbin size for elna supermatic 722010 Can I purchase metal bobbins for this machine at a Joannes? or ? Is there a staner bobbin number or size to ask for?? thanks@ The Elna I have came with ONE...
Elna Supermatic 722010 is a very vintage elna and would take the metal 7 hole dished bobbin like this.
Don't try to use any other bobbin in it, and always load and wind with the holes on top.
You can still buy these; one supplier is sewingpartsonline, here is like to the item
http://www.sewingpartsonline.com/bobbins-elna-426000-10pk.aspx
Aug 17, 2009 | Elna Heirloom Edition 6005
Remove bobbin race from Elna sewing machine
It is held in with 2 small screws but to remove it you must take out the feed dogs first.This is not really necessary. Get something sharp( like a small seam ripper that you may never use again) and cut the thread.Pull out what you can and then try sewing again. Should work.
sewman7
Mar 31, 2009 | Sewing Machines
1967 Elna Star series Supermatic
i have an elna model 62C supermatic purchased in 1972. on yours, do you mean the motor won't run at all? or does the electronic foot not cause a response to sew? after 30 years, in 2002, my electronic foot quit working. i opted to purchase the internal electronic module, and replaced it into the original housing (did it myself). the two weak spots in an otherwise amazing machine are the two plastic gears--rotary hook gear which works your bobbin, and the camshaft stack gear which works cams/zigzag/etc. i have replaced both in the last 5 years (again, did it with my husband's help). i'd say the Elna is pretty awesome sewing machine with the couple of million hours i've used it (no exaggeration!) and the minimum of repairs it has needed. an excellent source of parts is www.whitesewingcenter.com. parts are reasonable, and authentic. Raymond White is extremely helpful and knowledgeable. good luck. jeannie
Oct 30, 2008 | Sewing Machines
Elna supermatic bobbin and threading instructions
Check out these instructions and diagram. Good luck. Paste this link to your Address bar... http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
Sep 09, 2007 | Sewing Machines
Sewing Machines Logo
170 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
