(1)Assure the Brush Control on the hood is NOT set to the OFF position.
(2)Remove the brush assembly by pulling/unlatching it from base on each side.
(3)Does one of the brushes have the drive pin present?It should be about ¼ inch square, and two inches long.It attaches the brushes to the drive mechanism.
(4)Remove and clean the intake filter.One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen.Clean the hair/debris off the screen and reassemble.
carpet steamer will wash but not vacuum up waste water , cleaned out reserve tank and made sure...
(More)
carpet steamer will wash but not vacuum up waste water , cleaned out reserve tank and made sure underneath was clean
The upholstery attachment will not slide down and gets stuck because the space is tapered and the...
(More)
The upholstery attachment will not slide down and gets stuck because the space is tapered and the connector is not. Is there some other way of attaching? Brute force does not work.
