Question about Plumbing
When I pour a bath the shower comes on as well as the spout but only when the handle is turned to the middle position (warm). Turned all the way to hot or all the way to cold it seems o.k. I have a Moen single handled set-up with spout.
  • 129 Answers
I've never heard of this before. Nornmaly its shower or bath that is controlled by diverter on spout. All I can say is mabe try installing a new cartidge and see.
Posted on Oct 04, 2009
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
How do I get it to switch from bath mode to shower mode?!
If there is no divert er on the wall where the hand is then it is on the spout. The spout can have a little round chrome to pull or where the water come out you can pull it. This will make the water go up to the shower. Good Luck
Jan 06, 2011 | Delta & Single Handle Shower Faucet
Installed new tub/shower valve, water comes out of showerhead when water is turned on even though spout is open
the diverter valve is probably bad. put a new one in. the valve cuts off the water to shower, while running bath water.
Nov 23, 2010 | Delta Faucet Plumbing
We have Delta brand tub/shower fixtures, the one handle kind. The problem is that water comes out of both the tub faucet and the shower head, even though the shower is not turned on. This happens every...
You need to replace the tub diverter/spout. There are two kinds, I hope you have the kind with
an allen head set screw on the bottom side of the spout near the shower wall. These are super
easy to replace ! Loosen the set screw, twist the spout a little and it should slide off. When installing
the new spout, smear some vaseline on the copper pipe sticking out, this will help seal the new O rings in the spout.
The other kind of spout has pipe threads in it. They can be a little more tricky. I got called to a
house one time. The plastic female threads on the spout cracked when the plumber installed it.
The water ran down the inside of the wall and did damage down stairs. The leak could not be seen
until the sheet rock down stairs fell down from being soaked. You need to put some pipe dope on the threads, then tighten the spout on by hand, so as not to scratch it with a pump pliers.
I hope this helps !
Nov 03, 2010 | Delta & Single Handle Shower Faucet
Hot water on bathroom faucet won't get hot only luke warm
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
Apr 12, 2010 | American Standard Bath Faucet Ceramix...
I turn the shower on; half the water comes out of the bath and shower head?
the Diverter is not working. is it on the tub spout the pull handle type. just replace.
Jun 25, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Jun 14, 2009 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
Water coming from showerhead and bath spout at same time
Have whoever installed the shower set come back and fix the diverter. It should be a relatively simple adjustment.
Mar 15, 2009 | Kohler Home
Plumbing Logo
77 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
