Question about Garden
Blades do not stop when pto is off on m.t.d. mower yard machine
  • mickey813
    mickey813 May 11, 2010
    SOUDS LIKE ITS OUT OF ADJUSTMENT TELL ME YOUR MODEL AND SERL # AND ILL TRY TO HELP YOU
    Sergeant:
    Champion:
  • 257 Answers
I am not a expert just trying to help,,most of the time when the blades keep turning is the belt is getting worn or the brake on the quill is not working,,,hope this help
Posted on Oct 04, 2009
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Pto on MTDMOWERVSLOW model 670 is slowxto engage
Do you hear it kick over immediately when you pull the pto switch? Is it slow to build up RPM's of blade? I need a little more info. Could be bearings on deck going bad causing a slow rise in RPM's of blade.
Aug 01, 2013 | Yard Machines Garden
I have a 46" Yard Man riding mower with 20 hp BS.
Hello, Ask your local Mower shop if they show a Thermal switch for the PTO. You may have to replace it or move it away from the heat.
Aug 14, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
I hit a hidden log with the blade and it threw the belt. I replace the belt; however, now when I engage the PTO the engine dies.
Your log did more than throw the belt. Something is not able to turn, so when you engage the PTO, the blades stop the motor. Look for another belt jammed, or a bent spindle or piece of log jammed under the deck.
May 09, 2011 | Husqvarna 24HP 54" Yard Tractor ()
I had just started cutting grass with my John Deere L120 riding mower when the blades stopped turning. I thought the belt had broke or come off so I pulled into my garage to investigate. I turned the mower...
You have several safety switches on your unit. The engine should not start if the PTO safety interlock is engaged. Be sure PTO switch is off.
If the sarter Does Not Work Or Will Not Turn Engine Brake pedal is not depressed.
or the PTO is engaged.
Battery terminals are corroded. or Fusible Link in starting circuit is blown - (Not likely unless bad wires) Here is a link to your wiring diagram (maybe your model)
http://www.postimage.org/image.php?v=Pq1tOfiS
Notice how the starting circuit goes through the brake pedal (must be depressed) and the PTO switch (must be disengaged) and that the PTO only works with operator present. Print that page while link still works.
Aug 11, 2010 | Garden
Mower deck PTO switch will engage when pulled but stop when rele
The PTO switch has failed. There is an internal spring and plastic parts in toggle switches that keep them in the actuated position. It's not practical to take the switch apart to fix it, but replacement switches are readily available - probably $12 - $20. It's a good idea to disconnect the negative terminal from the battery before you do any electrical work. Be sure to put the wires on the corresponding terminals of the new switch. Good luck! Please rate if you find this helpful, thanks.
Jun 03, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Apr 25, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
