Question about Intec G5285 Racing Wheel Wheel And Pedals Set
Reseting and remapping buttons
I tried to remap a button and it did not work right, can I reset all the buttons? I tried to by restarting playstation. didn't work!So; I need to reset wheel buttonbs and learn how to remap buttons. I have no manual.
How to Customize Dell Media Direct Button to Hibernate?
Uninstall any programs having to do with Dell Media Direct from your computer.
Install Microsoft Intellitype Keyboard Software and Keytweak
26318734-bxzhjmonsmllydp0qa2riq2g-2-2.jpg Open Keytweak to remap the Dell Media Direct button to make your computer think you are actually hitting the "calculator" button on a multimedia keyboard even though we are using your standard-issue laptop keyboard.
  1. Click on Tools in the top menu and select Half Teach Mode.
Press the Scan Single Key button and then push your Dell Media Direct button. 26318734-bxzhjmonsmllydp0qa2riq2g-2-9.jpg
Select Calculator from the drop down list and hit Remap. 26318734-bxzhjmonsmllydp0qa2riq2g-2-14.jpg
Click on Apply and restart.
Give your Media Direct button a push and calculator should open up.
Right-click on the desktop and select New, Text Document. Don't worry about what to name it here because we will be saving as something different later.
In the text file, type: @echo off RUNDLL32.EXE PowrProf.dll,SetSuspendState
  • Lettering is case and space-sensitive!
26318734-bxzhjmonsmllydp0qa2riq2g-2-90.jpg Click File, Save As, Select your C:\ drive, and save the file as hibernate.bat 26318734-bxzhjmonsmllydp0qa2riq2g-2-104.jpg
Oct 19, 2016 | Computers & Internet
Control layout doesn't work well. Can it be remapped?
yes. the emulator usually has the button assignment under the preferences
Mar 03, 2014 | TTX Tech NXP3-050 Sony PS3 Wired USB...
German keyboard layout problem
The uses for mapping your keyboard are numerous, but remapping your keyboard's keys is not for the squeamish.
There are numerous software applications to map and remap a keyboard's keys.
The best part is that the software is free and easily downloadable via the Internet.
So, go ahead and swap those unused keys on your keyboard to suit your computing experience, and make your keyboard more effective without fear of damaging your computer
Place your mouse pointer over a key on the visual keyboard. Notice that the key is numbered.
To see what function the key is currently assigned to, allow your mouse pointer to hover over the key.
A pop-up displays what the key is attributed to.
Left-click the mouse pointer on a key you wish to change.
Click on Choose New Remapping from the drop-down menu.
Select Remap Key from the Control area on the interface.
You may also opt to disable or enable the key, and reset the default for this key.
Left-click Apply. Look at the list box at the top-left of the interface, labeled "Remapped keys currently in effect."
Ensure that the keyor keys you selected are listed in this list box.
Fix a mistake by resetting the defaults.
Click on the top button adjacent to the list box you just visited.
Pressing this button will remove all the changes to your keyboard mapping.
SharpKeys is a Registry hack that is used to make certain keys on a keyboard act like other keys.
http://www.randyrants.com/2008/12/sharpkeys_30.html
Jun 29, 2013 | Acer TravelMate 2500 Notebook
Have a 2002 camry check engine light has been on for years. had the catalyst convertor replace 2years ago. still did not fix the problem. have been told that when it was put in that the system needed to...
if you have had a fault with the oxygen sensors for a long time it is possible it has fouled up the catalytic converter.
if the engine check light is the one for routine service and oil change and there is no other fault, it may be possible to reset it yourself.
1. turn ignition key to ACC or LOCK position
2. ensure the odometer is shown and not the trip meters
3. press and hold the trip meter reset button
4. while holding the reset button, turn the key to ON position
5. keep holding the reset button for at least 5 seconds. the odometer will read "000000"
and the light should go off.
if it does not go off then the system will need to be remapped, possible after a new catalytic converter.
try the reset sequence first though
Feb 23, 2011 | 2002 Toyota Camry
Logitech Driving Force GT Wheel. Which is the Pause button?
I would of assumed it would be either the start or select button located at the bottom section of the wheel, unless the controls have been remapped... try them all :)
Oct 17, 2010 | Logitech Driving Force GT Wheel for...
My second row of buttons dont work. 4 5 6 subtract. evreything else does
If there are no hardware defects, a third-party game or application may have remapped the keypad. If that is the case (only you know what you were doing) uninstall the game or application. You do not have to delete it, just unload it from memory, and reset the calculator to recover normal behavior.
Hope it helps.
Do rate the solution and thank you for using FixYa.
Nov 11, 2009 | Texas Instruments TI-84 Plus Silver...
I accidently remapped my keyboard or mouse. How
Go to the Start menu and select Control Panel. Open the Keyboard folder and check the settings selected.
Oct 01, 2009 | HP EliteBook 6930p Notebook PC
My letter A button is broken
Pull it off and use air duster to blow dust out and put the button back on the keyboard. If its still broken, you need to buy a new keyboard.
Alternatively you can remap the "a" key to another key you do not use. See here: http://vlaurie.com/computers2/Articles/remap-keyboard.htm for how to do that manually.
Otherwise there are many apps that can do this.
Here are 2 free ones I recommend:
http://webpages.charter.net/krumsick/
http://www.autohotkey.com/ <- I like his program alot but it does more than key mapping. Its a full macro and hotkey application. Possibly more than you need.
Sep 06, 2009 | Computers & Internet
DSC W1 dead pixel
If it has the remapping option, it doesn't say so in the manual. from what I understand, every camera comes already with "dead pixels" and its already remapped so that you won't easily notice it. with time, more pixels drop off and you need to remap it again. Now the thing is, the remapping just makes the dead pixel an average of its surounding pixels, and there are photo editing programs that do the same thing, have the remapping option. so basicaly what i'm saying is that if you're out of warranty dont be in a rush to get it fixed. cheers
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Intec G5285 Racing Wheel Wheel And Pedals Set Logo
70 people viewed this question
Top Intec Video Game Consoles & Games Experts
Martin Murray
David
David
Colin Stickland
Colin Stickland
Are you an Intec Video Game Console and Game Expert? Answer questions, earn points and help others
