Question about Dryers
How to open the dryer and replace the belt
GE electric dryer, model number: VD7002KW419
I think the belt is broken, and I bought a new one.
But how to open the dryer and replca the belt?
Thank you.
  • 10er Mar 12, 2008
    I have a Kenmore Model # 110.74812200 Gas Dryer with a broken belt. I can pop the top like an automobile and pull out the belt, but I can't open the front panel because I can't figure out how to separate the electrical connection socket do-hickey in the top, front right corner of the machine. It looks child proof.
All dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Posted on Jan 11, 2008
How do I dissemble dryer ge model vd7002kw419
Go to www.repairclinic.com and enter vd7002kw419. With luck, you will be presented with a list of common replacement parts and may be able to view a generic GE video showing disassembly.
Aug 31, 2017 | GE Dryers
GE VD7002KW419 door pops open
That looks more like a serial #, anyway there is a small plastic square piece on the dryer and a short blade type on the door they fit together when the door is closed and hold it closed it sounds lkijke that is worn out and needs replaced
Apr 14, 2014 | Dryers
Need to identify belt parts for GE Gas Dryer DDG8580RCMWH
Check with an appliance parts supplier or directly with GE.
Jan 26, 2014 | Dryers
Hi. I have a GE dryer model VD7002KW419. It does not turn although the power connection is fine and I believe there is power. What could be the problem?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2011 | Dryers
My dryer's belt broke and I cant find the part
WE12X1001, WE12X1000, WE12M29 are the three different belts used on GE Dryers and if you go to
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and do a search on these parts you will be able to purchase them directly from GE. You will need to look at your belt and pull the number off if your belt in order to assure you get the right one. If you require further assistance, please do not hesitate to ask.
Jun 14, 2011 | Whirlpool GEQ8858H Dryer
General Electric dryer belt broken
Go to www.appliancepartspros.com and put in your model number. They sell new parts. Belts is around $10. Now the hard part trying to install it. This site will also give you a breakdown of the dryer and you can see how to get to the belt. GE pretty muck whole dryer has to be taken apart. Note when removing the front, hold drum in place and put something under it to hold it from falling. You will probably have to remove it anyway to get belt around it.
May 08, 2010 | Dryers
GE dryer drum hits idler pulley during rotation.
The belt is most likely either the wrong size (too long) or the belt has stretched. A new belt of the correct size should solve this problem. Make sure you have the model number when you buy the belt. I recommend that you take the old belt with you and verify that the replacement is a little shorter.
Apr 25, 2010 | GE DBXR463EBWW Electric Dryer
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
1,273 people viewed this question
Top Dryers Experts
