Question about Jenn-Air JCD2290HES Side by Side Refrigerator
I have a jenn-air model JSD2789GES, Ser 26301370CE. The light to change the filter came on and was changed following the instructions exactly. Purged the system with a Vase for about 5 minutes or roughly 4 gallons. The light remains on. I unplugged the refer and let stand for one minute to think about reset?? The light remains on. I got another filter and repeated the entire process as described, the light remains on??? It's been 24 hours now, the unit works fine, cold water and ice working fine, light still on the change the filter?? What am I doing wrong? Please, any Ideas? Thanks Rick Rowan General Contractor opps.... Reno nv. email rrickhalo@aol.com cell 775-815-7940
    President:
  • 1,304 Answers
Push light and lock for 5 sec
Posted on Oct 03, 2009
Testimonial: "worked like i knew what i was doing....THANKS"
How to get the red light change filter to reset after you hve changed the filter
press and hold the Light and Lock buttons until the filter light flashes (usually 5-10 seconds)
Nov 26, 2010 | Jenn-Air JSD2789GES Side by Side...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
Water Filter Item #
WHEN YOU CHANGE FILTER DO YOU NEED TO RESET LIGHT ON DOOR OR WILL IT RESET ITSELF AFTER CHANGING THE FILTER
Jul 14, 2009 | Jenn-Air JSD2789GES Side by Side...
I have a Jenn Air JSD2789GES side by side refrigerator and The water won't work to the ice maker or the water in the door?
Check if the water is on.
check if the water filter connected correctly or the bypass.If the filter is new and the appliance is new you should press the water handle or button till the water comes as the selenoid are open during you push.
Jun 30, 2009 | Jenn-Air JSD2789GES Side by Side...
Fridge not cooling
We will need to see if yours has the defrost timer or the adaptive defrost. Let me know if your model is the JSD2789GES. I have the manual we can work with. ..Sea Breeze
Jun 19, 2009 | Jenn-Air JSD2789GES Side by Side...
No cold air coming into the fridg
iF YOUR REFRIGERATOR SETTING IS HIGH, YOU NEED TO LOWER THE SETTING IN ORDER TO GET IT COLDER.
If you still have no air flow, there is a fan that blows cold air from the freezer to the refrigerator. The motor could be burned out.
Sqiudo
Dec 15, 2008 | Jenn-Air JSD2789GES Side by Side...
I have a jsd2789ges jenn air water dispenser not working at all
hi there,
sounds like you have an icemaker problem. i would recommend replacing it.
Oct 02, 2008 | Jenn-Air JSD2789GES Side by Side...
Getting light to turn off after changing water filter
Press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks
Jul 30, 2008 | Jenn-Air JSD2789GES Side by Side...
Change filter light
the light goes off only upon reset. the instruction calls for pushing and holding two of the buttons in, together, until the light goes off. it should work
Jul 21, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2290HES Side by Side Refrigerator Logo
206 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
