Question about Raymarine Boating
Display control unit frozen, display just reads standby
My raymarine (raytheon) st6000 autohelm,Display control unit has frozen, display just reads standby, none of the control buttons work, can control autopilot with chart plotter raymarine(C80)
  • 43 Answers
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Posted on Oct 13, 2009
Autohelm st5000 bypass
There should be a button marked Standby on the top of the unit. Press it once and the unit will go into standby mode.
May 10, 2014 | Raymarine Boating
Autohelm st50 wind
Go to Raymarine.com to find the usermanual for these units. They should be helpful.
May 06, 2013 | Boating
ST6000 controlhead shows full display with all segments when switched on and does not change when pressing various control buttons Thanks, wilhelm sevenseas@telkomsa.net
Raymarine told me the unit was faulty. I stripped and found corrosion on one side of the circuit board. After cleaning it worked again. I suspect there is probably corrosion on the other side of the board as well but not sure how to acces it. Afraid to break the CB trying to remove from housing
Nov 10, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
My GPS Raymarine (installed in 2001) with Raytheon Raystar 120 antenna indicate offen a NO FIX. A technician tells me that there must be a problem with the antenna and that the best solution is to...
Before you buy a new one if that is a raytheon raystar unit there is a lithium battery inside the unit check that first thats all you may have to replace.
Sep 04, 2010 | Raymarine Raystar 120 GPS Receiver
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
May 21, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Looking for spare parts for Raytheon ST6000 autohelm. Raymarine says parts for this model are no longer avail.
What parts are you looking for? Some parts are interchangeable between the old and the new. Let me know: kevin@sun-me.net.
May 06, 2010 | Raymarine Boating
Need power supply cable raytheon v850
Anything Raytheon is going to be tough now since it is no longer supported by Raymarine. You may still be best to start by calling Raymarine's tech dept to see what they say. If no luck, your next best try is probably EbaY.
Raymarine Tech support 18005395539
Aug 04, 2009 | Raymarine B60 12 Tilted Element Transducer...
St6000
The linear drive should have an adjustment screw on the arm so that it can be adjusted to show when the rudders are central. you will need to centre upm the rudders then loosen the screw and adjust until the guage shows the centre position. May take some fiddling to get right cause sometimes when you centre it the guage won't read correctly in the port or starbord directions (won't go all the way over). May need to re-position the whole unit.
Sep 02, 2008 | Raymarine Smartpilot Autopilot St6002 S1g...
Boating Logo
459 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
