Question about Garden
I have a Craftsman 625 push mower. I think the choke is stuck
I have a Craftsman 625 push mower. It's been fine until today. Now, it's eating gas and smoking a bit, and cutting out. My brother says the choke sounds stuck but I can't find any choke (maybe the red primer button?) Can you help?
  • 6468 Answers
SOURCE: red primer button stuck pushed in on 550 series mower
sounds like the pasagges are plugged up
Posted on Apr 01, 2012
  • 56 Answers
SOURCE: 18.5 sears craftsman yard tractor won't run right
The fuel filter needs replaced or the carburetor needs cleaned.
Posted on Apr 07, 2009
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
  • 11 Answers
SOURCE: my push mower won't stay running.
Change out gas for fresh stuff. Try it. If not, take off carburator and clean thoroughly. Clean the foam filter assembly as well. Make sure gasline and vent line are clear. Also check the vent cap on the fuel tank. Sometimes it can make a huge difference taking out the sparkplug and removing the filter on the carb, then take some carb cleaner and while your buddy pulls the cord, spray some carb cleaner through the carb. It will travel into the cylinder and immediately out the top, so be careful. No danger of ignition because you took out the sparkplug, but you dont want that stuff in your eyes.
Posted on Aug 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a Craftsman self propelled lawnmower. It
Hi sharonld 123...
Check/Clean/Replace your fuel filter if you have one.
If the mower/weedeater/edger is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 28, 2011
Why is my Craftsman lawn tractor so hard to start?
Most likely needs valves adjusted. If you can give model number off of the engine, i can try to find the manual or instructions on how to do this for you.
Jun 28, 2014 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have a craftsman 20 OHV Intek Plus riding mower on the throttle lever is also the choke is above the rabbit and my wife got on the mower and wanted to go faster and pushed the throttle lever all the way...
Hi, it may have saturated the air filter with fuel. Try it without the filter, if ok dry or replace the filter. Hope this helps, regards Phil.
Aug 13, 2011 | Garden
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Won't start. Has compression. backfiring through
On many riding mowers there are two wires that at the bottom of the carb bowl, these wires go to a solenoid which closes a valve so gas will shut-off when the start key is turned off. When this solenoid is bad it will not close which let gas keep going to the carb so the eng will bang through the carb or muffer. Hope that this will Help. Hugh Lyon
Jul 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Apr 07, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
