Question about Enfocus PitStop Professional 08 Full Version for PC, Mac
Upgraded to Access 2007 but now will not open 2003 database. Comes up with "You do not have permissions.. contact your administator or the the person who created this database..."
    Guru:
  • 830 Answers
Find the database you wish to open, right click on the file and uncheck read only.
next, you will need to convert the database to a 2007 files. See instructions in PDF file:
http://www.tr.tcu.edu/files/ConvertDatabaseTo2007.pdf
Posted on Oct 03, 2009
How do I easily repair corrupt or inaccessible Access database file?
Why to depend on anyone else suggestion. You may download one of the best access recovery tool which will repair your inaccessible access database file. This tool work on windows 10 & below versions also best thing is that free version of this tool will preview all your records after repairing your database. So you may preview your database and can easily review that your data is recovered and to export it you have to use full version. Try this access recovery tool. Access Recovery Tool Repair and Manage MDB or Accdb Database Files
Sep 09, 2015 | Computers & Internet
Access 2007 corrupted database
You may try this third party tool programmed with best technology the tool support all windows and MS office versions. You may try free demo version of this software to preview your recovered access database. SysTools Access Recovery you may check How tool works and its user friendly interface make this easy to handle.
Jan 11, 2015 | Microsoft Office Professional 2007 Full...
Access 2007
Check the following link: http://support.microsoft.com/kb/928091/en-gb
Use the procedure to bypass the auto-registration for Word 2007 for Access. It should work perfectly.
If you need further assistance, leave a comment. Cheers
Jun 07, 2010 | Microsoft Office Professional 2007 Full...
What is the extension file name for a microsoft access file?
According to Wikipedia:-
Access Project .adp
Access Blank Project Template .adn
Access Database (2007) .accdb
Access Database Runtime (2007) .accdr
Access Database Template (2007) .accdt
Access Database (2003 and earlier) .mdb
Access Database, used for addins (2,95,97), previously used for workgroups (2). .mda
Access Database Template (2003 and earlier) .mdt
Access Workgroup, database for user-level security. .mdw
Access (SQL Server) detached database (2000) .mdf
Protected Access Database, with compiled VBA (2003 and earlier) .mde
Protected Access Database, with compiled VBA (2007) .accde
Windows Shortcut: Access Macro .mam
Windows Shortcut: Access Query .maq
Windows Shortcut: Access Report .mar
Windows Shortcut: Access Table .mat
Windows Shortcut: Access Form .maf
Jun 03, 2010 | Microsoft Office Access 2003 (077-02871)...
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
Resolution
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 (http://support.microsoft.com/kb/253604/ ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 (http://support.microsoft.com/kb/189408/ ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Oct 16, 2009 | Microsoft Access 2003 for PC
Outlook 2007 upgrade freezes on startup
You say that you have upgraded to Outlook 2007 from Outlook 2003; were you using any personal folders (.pst) in Outlook 2003?
If the asnwer is yes; then were these personal folders created in Outlook 2003 or some earlier version of Outlook? In any case, if the older type personal folders are large in size, these can cause Outlook 2007 to stop responding or freezing.
Close Outlook 2007; right click on the Outlook icon showing in the startup programs bar and choose properties; choose 'Show Profiles'; choose copy profile and then choose this new profile in the 'Always use this profile' option.
Outlook 2007 should now work fine.
May 26, 2009 | Microsoft Office Outlook 2007: Windows
Problem opening Access Database-upgrade from Access 2003 to 2007
if the form "products" really exists, then your office 2007 security settings are not allowing to load macros. Try the following settings:-
Office 2007 has some security settings disabled by default to prevent any harm to your system.
go to trustcenter settings(click the office button at the top left of the office 2007 screen then click Access options, then select Trustcenter, then click trustcenter settings.)
In trustcenter settings, select message bar then select "Show the message bar in all applications when content is blocked" radio button.
Then from macro settings ,make sure to select "Disable all macros with notification" . Click ok twice to close the settings windows and try opening the file again.
Good Luck
Mar 25, 2009 | Microsoft Access 2003 for PC
It seems that you have your Database(.mdb) file is created in Office 2003.... thats why you are unable to open it in 2007.... I faced the same problem.... then I came back to 2003 in order to use our database......
Mar 25, 2009 | Enfocus PitStop Professional 08 Full...
Upgrading from 2003 access database to 2007
I would leave your database as Access 2003. the 2007 version has many bugs and will give you many more problems than its worth. Access 2003 is very stable, you should be able to keep it at that for many years.
Apr 22, 2008 | Microsoft Computers & Internet
Enfocus PitStop Professional 08 Full Version for PC, Mac  Logo
79 people viewed this question
Top Enfocus Computers & Internet Experts
David Payne
David Payne
Are you an Enfocus Computer and Internet Expert? Answer questions, earn points and help others
