Question about Whirlpool Refrigerators
Whirlpool refrigerator door reversal
Hello. I am in Australia. We have a Whirlpool WRBE43TW refrigerator. I wish to reverse the fridge doors from right opening to left opening. Everything looks perfectly reversible, except for the centre hinge between the fridge door and freezer door. This hinge is not symmetrical. Am I missing something? Is a left opening hinge available please? I will try to get an answer from Whirlpool next week if necessary, but was hoping to sort this out this weekend. Many thanks for any help!
5 Suggested Answers
  • 958 Answers
SOURCE: We have a fridge/freezer, upright
if you can notice that the doors have plastic plugs to the other side of the hinge then it is design to be reversible.
but if there is no indication that you can transfer the hinge to the other side of the door, then it is not designed to be reversible and there is nothing you can do about it.
i'm not sure if the old fridge are designed to be reversible.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
SOURCE: Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
Posted on Aug 08, 2009
alicantecoli
  • 22326 Answers
SOURCE: door reversal on fridgefreezer
Ask a big strong macho man as they can be a bit tight at times
Posted on Dec 02, 2011
  • 884 Answers
SOURCE: whirlpool refrigerator door reversal
Check with supplier first but almost all fridge bodies are made for reversal
Posted on Apr 22, 2012
How do I reverse the doors on my whirlpool ET18NK
There are screws on the top and bottom of the doors & fridge itself, look for the rubber(sometimes plastic) caps covering them. Just reverse the screws to the opposite side you prefer. USUALLY REQUIRES 2 people to reinstall
Apr 07, 2016 | Whirlpool Refrigerators
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
Reverse door.
Some cannot be reversed....
May 28, 2015 | Amana Refrigerators
The doors open in the wrong direction
remove top screw for freezer door remove door then remove next hinge then remove fridge door reverse hinges when putting back on reverse handles to other side
Mar 01, 2014 | Thetford NORCOLD N641R - Norcold Finished...
How do you reverse the doors on norcold n641r fridge
remove freezer door first then fridge door change handles and reverse hinges
Mar 01, 2014 | Thetford NORCOLD Refrigerator Lower Door...
Apr 22, 2012 | Whirlpool Refrigerators
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
We have a Bosch Fridge Freezer Model No KGV3120GB/03 we wish to reverser hang the doors but can't undo the top post in the fridge and bottom one in the freezer don't want to apply too much pressure in case...
We have just reversed the doors on our Bosch Fridge Freezer. The posts were very difficult to unscrew but was eventually possible using 2 mole grips. It is definitely a screw fitting. Good Luck.
Jan 02, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
We have a fridge/freezer, upright bought some 15 years ago. Works fine, but we wish to reverse the doors to right opening from left. Please advise how to do it.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Refrigerators
Refrigerators Logo
182 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
