Question about ECHO, Inc. PB-251C Handheld Blower
Weed eater lawn mower pull cord locked up
I was mowing taller grass and the mower stalled. i picked it up from the back to see if there was grass clogged in the blade. i didnt see anything but the blade wouldnt budge. i tried to pull start the mower but the cord would only move 2in. or so. i turned it on its side (probably not the best idea) and i unwound a bit of thin stringy weed from the cylinder. i could move the blade around but it was tough. i turned the mower right side up and oil started leaking out of it. still no give on the pull cord. i just bought the mower off of craigslist and it looks to be in good condition and it started on the first try. this was my first time using it to cut grass. i dont really have the money to take it to a repair shop and just want to know if i might be able to fix it myself and how.
3 Suggested Answers
SOURCE: Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Posted on Jul 09, 2009
  • 5 Answers
SOURCE: weed eater is locked up. can not pull cord at all.
Try taking the cover off around the pull if you can. Likely the cord is not free to spin, or there is a rub on the fly wheel stopping it from moving.
Posted on Aug 25, 2009
Black,dry carbon soot over lawn mower.
if the mower was tipped over oil will run into the cylinder and the carburetor. yes it sounds like oil burn off
Sep 20, 2016 | Garden
Im having truble puting the starter cord and springs back in my husqvarna weed eater 128ld
You have to take it apart, get the spring back in, then wind the cord around around it. Not an easy task if you've never done it. A small engine repair or lawn mower repair shop will fix it pretty cheap and fast.
Apr 22, 2016 | Husqvarna 128 LD Weedeater
Weed Eater WT 325. Where can I get a replacement pull cord?
Hi Graeme, Ant lawn mower store sells them....
Apr 01, 2016 | Garden
Mower is not picking up grass plugging in chute
Did you just replace the blade ? If so, it might be on upside down, which would produce no upward suction.I assume you're not mowing right after rain. If there's a buildup of old grass gunk around the chute, scrape it off. Remember always to pull the plug wire off before reaching under the mower!
Mar 07, 2015 | Garden
I have a riddeing lawn tractor and on its highest setting cuts grass too short how do i raise the deck to get a taller grass
if you look under lawn mower were the deck attachs you will see the adjustment rods unhook one at a time to adjust ether screw the rod in or out do this on a driveway so you can measure with the tape measure how for you or lifting deck and can match hight on both sides
May 14, 2014 | Yard Machines 13AC762F000 38-Inch 344cc...
Lawn mowers
Maybe it need a spark plug
May 08, 2013 | Garden
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
ECHO, Inc. PB-251C Handheld Blower Logo
877 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
