Question about Saws
Will not run..there is 120vac on either of switch, but no ac at brush contacts...is switch defective? This is a Bosch Model B-4050 inline jigsaw
    Problem Solver:
  • 14 Answers
Place a jumper wire on each side of the switch. Be careful because you are dealing with 120vac. Then plug it in for just a split second. If the jig saw operates its the problem is in the switch.
Posted on Oct 03, 2009
Bosch pks 2 stopped working
Or a cable break problem replace cable class2 ho5rn or a carbonbrush is on its end (thats protected insite the brush self) replace both brushes if thats not then one of the electric field contacts are broken and if thats not the switch is defect or only the contact of the cable is loose. more options are not available 1 collector on the armature could be as last option is defect .
Aug 16, 2013 | Bosch Pks 40 Circular Saw 600W
My Bosch jigsaw suddenly seems to run too slowly. It just doesn't cut as agressively as when new, and seems to turn less rpm. what's going on with it?
This may seem dumb but did you accidentely turn the variable speed dial on the trigger down? Not sure which model you have but that is the most common problem that comes into my shop with certain models.
Dec 17, 2012 | Bosch Saws
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
I replaced the switch the cord and checked the brushes everything looks fine but it won,t work. Help
Interesting. I looked at the following URL to see if there was any safety device that might prevent it from working and I see none:
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1274DVS
If there is nothing happening when you pull the trigger, the only thing you can do is trace the wiring from the power cord through the trigger and to the motor contacts, as shown in the aforementioned URL diagrams. I assume the motor has not seized up on you since you did change the brushes. Not to sound foolish, but did you try changing the outlet you plugged the saw into? In some of the higher end equipment there is an inline fuse that is part of the AC plug assembly. Any chance that is part of the new cord? Blown or missing in-line fuses?
Please keep me informed of your progress as I find this quite interesting. Paul
Sep 18, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
WANT TO FIND PARTS LIST FOR BOSCH PST 54 PE JIGSAW
you can trying going to Boschtools.com and you will need the exact model number, the parts list section is on the left hand side of the page towards the bottom.
Jan 25, 2010 | Bosch Saws
Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Jul 28, 2009 | Bosch 1581AVSK Top Handle Jig Saw Kit
My 9 month old Bosch 1590 jigsaw will not start??
The problem is the switch, or trigger switch. It may just have saw dust in it or it may be shot. Try blowing the dust out of it with a good blast of compressed air. If you don't have a compressor to do this go to a tire shop. They will help u.
Jun 20, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Saws Logo
77 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
