Question about LG LFD790 System
Remote Code I would like to use my DirectTV remote to control this home theater systems volume. The code from the DirecTv DVR does not work. Any suggestions?
SOURCE: No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Posted on Aug 31, 2008
SOURCE: I have ATT U-Verse and
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Posted on May 03, 2009
  • 151 Answers
SOURCE: My furkid ate the remote...
pick original, not replacement.
Posted on Oct 19, 2009
Testimonial: "Thanks for the link & the heads up about the original...for the gamers in my house, the replacement wouldn't have been what we were looking for!"
  • 123 Answers
SOURCE: I need the code to
We would be happy to help you with getting yourDISH Network remote to control your LG LHB335. Pressand hold the AUX button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecode 2*836. Press the pound (#) button. To check that thecode works try several different functions on the remote to make sure it willproperly operate your theater system. Keep in mind that some codes may not be compatiblewith your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service
Posted on Feb 22, 2011
  • 123 Answers
SOURCE: I moved into a new
We would be happy to help with that. Please keep in mindthat the code provided will only be compatible with either the 20.0 or 21.0model remotes. The model number of a remote can be found on the back of theremote, close to the top. The first thing we want to do is hold the AUX buttondown until all the mode buttons on the top of the remote light up, thenrelease. Once the AUX button is blinking, press 2 then * then enter 836followed by the pound (#) button. The AUX button should blink 3 times and youshould be able to operate your LG LHB953. Remember to put the remote back in SAT mode after you'redone. Althoughwe try and facilitate using your DISH remote to control other devices, thiscode may not be compatible with your equipment. Thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
SOURCE: Need Remote Code for LG LFD790 Home Theater
Posted on Apr 02, 2011
0 characters
1 Points
I need the code to program my tv to dish remote control
Use the search method on the repoteit allows you to go through all the codes until it finds the right one. Look it up on your satellite provider site or do a Google search for (example) "Directv remote control codes" If it's Directv try the attached link DIRECTV Remote Control Code Lookup
Jan 03, 2015 | Mitsubishi WD-73642 73-Inch 1080p 120 Hz...
My Comcast remote will control my LG LHB535 receiver/blue-ray player in all respects but the volume. I used code 20591.
You need to change the volume lock for the remote to go to your AV receiver, not the TV. By default all Volume control will go to the TV, but you can change volume lock to go to AV receiver instead. I switched to DirectTv and had to do the same thing, so I may not have the right term used on comcast, but essentially the same thing.
Dec 29, 2010 | LG LHB535 Theater System
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
The Directv codes for my Samsung HT-TZ512 surround sound/dvd player don't work. How can I program my Directv remote to control the dvd player? The codes I've tried are 20490, 20573, 20820, 21075 and 20899....
sometimes directv remotes do not work with surround dvd players. Try doing an automatic code search . Most of the time it will only allow you to power the dvd player and operate the volume.
Oct 23, 2009 | Samsung HT-TZ512T Theater System with...
Remote control codes for bose
The DirectTV Website has a page to find remote control codes, and it lists lists four different remote controls to choose from. Find it here:
I fired "Bose Lifestyle" into the first choice and it gave me the numbers
here are the instructions from that page:
Setup Instructions
  • Set the "Mode Switch" to AV 2.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • I hope that helped.
    Sep 19, 2009 | Bose Lifestyle 48 System
    Need v30 bose code for remote
    Bose V 30 works on Radio frequency ............. so you need to have a unversal radio frequency remote conrol..... no IR (infrared) remote can control a bose lifestyle product..
    why not use your bose radio frequency remote( the v 30 remote) to control the dvr plyer from motorola.. you can used the remote even to control your tv and other deices ..
    all codes for your other systems are available in th e system settings option under remote control category to set up your system to control other devices
    Feb 21, 2009 | Bose Lifestyle V30 Home Theater System -...
    Time Warner Remote Code to work volume for Philips Home Theater
    after much trial and error i found a code that partially works.... 3025
    it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though
    Dec 23, 2008 | Home Theater Systems
    Bose remote device code for directv satellite box
    im living in st maarten nederlands antillies on the dutchside and i boutgh a sitilite box in newyork i ask the people if that can work in ST.Maarten they said yes but ST.MAARTEN is dish network i cant find the code program for the box that box is direct plus hd dvr directv satilite reciever. please can you help me.
    Dec 01, 2008 | Bose 3 2 1 GSX System
    Remote Code for HDX500/I
    Get a Logitech Harmony 880 universal remote. I have it operating my home theatre, TV, iPod and cable just fine - all with one remote.
    Nov 19, 2007 | Sony DAV-HDX500 System
    LG LFD790 System Logo
    Top LG Home Theater Systems Experts
    Electro Med Services...
    Sudeep Chatterjee
    Sudeep Chatterjee
    Are you a LG Home Theater System Expert? Answer questions, earn points and help others
