Question about Sony FD Trinitron WEGA KV-32FS210 32" TV
Does not come on. there is power to it but it does not com on. every once in a while it seems to be trying. like a surge but then notheing.
    Scholar:
  • 78 Answers
The tv is more than likely full of bad current and needs to be discharged. unplug it for about 24 hours, and then plug it back up and try it again......about 12 hours into the unit being unplugged, hold the power button down randomly for about 30 seconds at a time........plug the unit back up, try to turn it on, and listen for any unusual noises.....if you can, try to smell....yes smell.....the vents on the to back side of the tv, to see if anything smells like it is hot, or "frying"....everyone knows the smells of something electrical that is hot, and if you dont, you'll know it when you smell it.
if you encounter any of these issues, the nunplug the tv and dont try it anymore. you're last options would be a warranty exchange through the manufacturer, or taking it to a tv repair shop, or simply buying another tv. it's just limited on what you can do, as far as repairing the unit yourself goes, as there are several part of the tv that can hold enough current for up to 6 months, that WILL kill you, if you even so much as touch them. obviously i do NOT recommend trying to take the unit apart.
Posted on Oct 03, 2009
After power outage with a power surge. Our two Liebherr CS1311 are only blinking double dashed lines for the freezer temp and nothing seems to be working other than the lights and control panels.
If the compressor happened to be running when the power surge happened, it's possible the motor inside the compressor has failed. There are safety devices on the compressor that may have gone bad too. The electronics in the controller don't do well in surges, so that may be the problem too. It all comes down to how much the repairs will cost added to what you already have done to it against the cost of a new unit.
Dec 05, 2016 | Liebherr Refrigerators
Oven is two weeks old. Town had a power outage we reset at breaker but still just beeps once and nothing happens
power outages cause power surges when the power comes back on
this surge generally manages to fry the power/control board
I suggest that you get the services of the service centre to come out and check it out.
May 30, 2015 | Bosch 27" Double Wall Oven HBN56
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
Bose remote will not work after power surge
the power surge . Nothing had to do with the power surge. Maybe you must check the C.breaker or reset button from the device, TV, Dvd, OR Whatever . and try again.
Reset the code from remote control, replace the batteries, clean the batteries contacts. retight the springs contact batteries for better contact and try again. download the code www.remotecodelist.com and instruc.manual from www. fitness.manualsonline.com
God bless you
Sep 02, 2012 | Bose Televison & Video
My Samsung LN40C530 F1F just went out last night no power nothing I had it plugged into a surge protector, I tried an alternate power outlet I just purchased this TV last year July 10, 201.
Try without the surge protector.
Sometimes the power supplies go bad (could be your issue). Sometimes the back-lights go bad and it will seem like it is powering on (red light goes on/off) and you get audio but no picture.
You will be better off getting a new one rather than getting this one fixed. Unfortunately, sony and samsung are the best two brands. You can try calling Samsung to see what they will do for you (so close to your one-year warrantee).
Good luck.
www.samsung.com/us/SUPPORT/
Jul 16, 2011 | Televison & Video
Olevia 37" no picture
check the TV power cord first., try to plug any other appliances on the same surge protector or outlet, like electric fan, electric iron., see if's work., if it does, probably the power supply of your TV is in trouble.
May 09, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My lap top worked just fine in the morning and went into sleep mode. The computer was unplugged so there isn't a power surge issue. I've tried shutting it down by holding down the power key, I removed the...
try the following steps.
1.remove the battery pack
2.press and hold the power button for 30 seconds.
3. plug in the ac cord to the wall and to your laptop, (make sure the light indicator on ac adapter is on)
4. press the power button once to turn on
IF this process fails, more likely you have a motherboard issue. South Bridge chipset may need to be resoldering or replaced
hope it helps yuva
Mar 26, 2009 | Computers & Internet
Power surge on hub port
I am having to send my wife's curve out for repair today as it seems that the very fine connections made to the circuit board from the power port have come away. This port seems to be very fragile, and poorly designed IMHO given that it has to be used so frequently.
Sep 03, 2008 | RIM BlackBerry Curve 8310 Smartphone
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Sony FD Trinitron WEGA KV-32FS210 32" TV Logo
107 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
