Question about RCA 27V530T 27" TV
Need to change rca tv from widescreen to fullscreen
How do i change rca tv from widescreen to fullscreen, did it before but can't remember
How can i switch my sylvania mts sap tv from fullscreen mode to widescreen mode?
kindly check the remote settings and your manual for it. Select Menu and click Settings, then sort it out until you see the option Wide so that you can select it to widen your screen..
Sep 06, 2011 | Sylvania SRT2232S 32" TV
How do i get the viewfinder to show fullscreen. At the moment there are 2 black strips down each side in "iauto" mode. When i first had the camera it was fullscreen. Thank you.
The LCD screen on the Olympus SP-800uz camera is widescreen (16:9).
If you set the camera to take pictures in (4:3) ratio you het the black sides.
Solution:
Select a Widescreen Image Size (see the manual page 30) by selecting one of
the available Image Size settings 16:9 (L) (4288×2416) or 16:9 (S) (1920×1080).
Jun 12, 2011 | Olympus SP800UZ Digital Camera
Please help me. I am trying to watch Avatar on my LG Dvd player. It works only in Fullscreen and will not play in Widescreen.
Check the dvd menu should have a choice to pick widescreen or fullscreen.Not,at the begin of the movie will have paragraph or audio anouncement it said it playing fullscreen to fit ur tv.
May 04, 2010 | Televison & Video
My dvd player is switching between widescreen and fullscreen randomly
How do you know it's the DVD player? Could be the TV or anything in between them. Connect one video output directly to your TV and if it is happening frequently enough you should be able to narrow it down to the DVD or one of its outputs; or something else. BTW: model numbers are helpful in these discussions.
May 05, 2009 | RCA Audio Players & Recorders
Picture format to large
There should be a format button on your remote to change between widescreen & fullscreen as well as the zooms. May say format or aspect. If not on remote look through your menus. Make sure which ever u select u do not choose a zoom. This will cut of top & bottom of picture
Apr 06, 2009 | Televison & Video
HALF OF THE SCREEN
Are you referring to the black bars that show above and below the movie? That's normal, it's called widescreen aspect ratio.
If you don't like that, you want to buy/rent fullscreen movies.
Widescreen is 6:9, fullscreen is 4:3. (Square versus rectangle)
Mar 19, 2009 | Durabrand DVD-1002 DVD Player
Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Nov 13, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
RCA 27V530T 27" TV Logo
601 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
