Question about Acer Computers & Internet
Boot up after refit shows error loading bus6
This is an acer aspire 3100 laptop originallya had a 80GB hd and 512 MB RAM now has 160GB hd and 2 GB RAM
boot up after refit shows error loading bus6 device4 function0with new hd and RAM
Benimur
  • 6966 Answers
SOURCE: How easy is it to install RAM into a new sony vaio VGN NR110 laptop
Most current laptops have a lid/panel underneath the bottom covers hiding the memory. You need to turnover the laptop and visual inspect the bottom panel/cover. Memories often are readily accessible to the user. They are underneath a lid/panel which is roughly squarish about 2 X 2 inches. It is normally held in place by small screw(s). Upon screw removal, you need to pry open the lid cover to expose the memories. Pressing sideways on the 2 retaining clips of the memory would pop it out slightly which should then be relatively easy to remove.Popping in new memory is the reverse. Diagonally insert the new memories into the slots to initially set them in. Gently but firmly press on the memories downwards to lock them in place. You will notice that the 2 retaining clips will automatically lock in place.
Alternately, for a few more, you can purchase the memory from any computer shop/store and ask them to install hereby assuring yourself that the job was done right. Further the store will not have any excuse/reason when the new memory malfunctions and can be readily replaced.
Of course yo can do it yourself, it is relatively a simple job and if you are willing to take the risk (very minimal), go for a DIY (do-it-yourself).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Dec 07, 2007
  • 395 Answers
SOURCE: Upgrade the shared graphic memory
there should be a setting in the bios to adjust the shared memory with video.
Posted on Feb 04, 2009
  • 31 Answers
SOURCE: I bought a used acer aspire 1360 with no hdd. I
that laptop only works with a 7900mb hd the only way to fix that is to either buy a upgrade kit for that model if available or get new laptop probably cheaper just to get new one sorry
Posted on Mar 27, 2009
  • 497 Answers
SOURCE: Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Posted on Oct 12, 2009
Testimonial: "Thanks Mitesh for the information its was very useful"
  • 226 Answers
SOURCE: I WANT TO CHANGE MY HDD 80GB AND 512 MB RAM
Go to Crucial or Viking or any memory company on the web, type in your model number, and they will provide the proper memory module advice. You can remove the cover from the HDD on the bottom of the toughbook, and inspect the current disk to determine if it is SATA or not. I would check the manufacturer and series (model) and see if they had a larger in the same series. It will be labeled if it is SATA or EIDE, and you would get the same in a larger internal size.
tom
Posted on Dec 22, 2009
How do yo get to the memory and can I add 1GB to the existing1!GB or do I have to purchase a 2 GB memory...thanks
Most laptops have 2 memory slots, if you have 1 Gb of RAM using two 512 Mb RAM then you need to replace them with two 1 Gb RAM modules. If you have one RAM module 1 Gb then you only need to add another 1 Gb RAM module. Try to use the same make and speed RAM.
Aug 19, 2010 | Acer Aspire One A150-1006 Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
Acer aspire 1600 four error code on pre boot then
Please reseat your RAM, and your CPU. Also check that the CPU is locked tight and that the RAM is seated properly. Run off A/C without battery then test with Battery only then with A/C on and battery connected.
May 22, 2010 | Acer Aspire 1604LC PC Notebook
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Ihad a ACER Aspire 5052AWXMi, AMD Turion MK38,
yes you can upto 2GB and 160GB HDD
bkas your laptop having DDR ram, 80GB is ATA HDD,
Jun 22, 2009 | Computers & Internet
My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
Mar 17, 2009 | Acer Computers & Internet
Computers & Internet Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
