Question about Toshiba Satellite A305D-S6848 Notebook
Integrated chicony webcam driver seems to be current and installed, but webcam seems to not exist. It used to show and work fine, but once I installed AVG virus blocker it seems as if it does not exist.
    Problem Solver:
  • 5 Answers
I know this is an old post, but just in case others are having webcam problems with their a305d webcam... There is a problem with many a305d satellite web cams, the cable/wires that connect the webcam to the motherboard are weak and badly routed. They usually fail due to fatigue at the hinge where it flexes/bends every time the lid is opened/closed. The first symptom usually comes in the form of random Windows USB connected/disconnected sound notifications when the lid/screen is moved. The second is a random USB device not recognized error. Finally, when the cable totally fails, you get a camera driver not loaded error. I've seen bunches of these units with this problem and usually repair it by cutting and removing the section of cable at the aforementioned bend in the hinge area, then soldering and heat shrinking the repair. I then reroute the now shorter cable behind the monitor rather than around it. I do this because it's easier and cheaper than sourcing a new cable and allows a faster turnaround time.
  • So, even tho the OP attributed their problem to software, it may not be the actual problem at all. You see, most of the time users blame a newly discovered problem on the last major system event (software or hardware installation, removal or failure). It is a good place to start after all and many times they're right, but just as often they only noticed the problem after the event and the event has nothing to do with actual problem at all. As a tech I see this all the time.
Posted on May 04, 2011
  • bewiens Jun 19, 2011
    Haven't taken apart my A210 yet, but after months of trying software/driver-related fixes, this has to be what's wrong. You described my computer's webcam issues perfectly. This seems to be a problem with many toshiba laptops with chicony webcams. I wish I knew how to solder, lol.
How to turn on my built in ebcam
Many Toshiba laptops, including Satellite, Portege and Qosmio models, feature built-in Chicony-brand webcams. The Chicony webcam can be problematic, especially when running a 32-bit version of Windows Vista. Microsoft has released an update that will correct problems with starting the webcam after terminating "Sleep" mode. Users may also have to install the appropriate driver or webcam software to correct webcam problems.
Dark or Black Webcam Image Problems b> Toshiba laptop owners may have problems with the webcam displaying as dark or completely black a few seconds after the initial image appears or immediately after engaging the webcam. Users should ensure that the webcam indicator light is engaged. If not, users should run the "Camera Assistant Software" to turn on the webcam. Low light can cause the webcam to power off and to display a dark image. Users can tweak the light and contrast by manually increasing the lighting in the room or by turning on "Night Mode." If these steps do not correct the dark image problem, users may have to reset the webcam itself, reinstall the "Camera Assistant" software. b> Webcam Problems After Terminating Sleep Mode b> Toshiba laptop owners with Windows Vista (any 32-bit edition) installed and the Chicony webcam may have problems starting the webcam after restoring the laptop from "Sleep" mode. "Sleep" mode powers down a number of hardware components in the laptop. The webcam is capable of entering a non-operating system-induced sleep mode when it is not used for an extended period of time. After the user engages Windows "Sleep" mode and wakes the laptop, the webcam may give error messages such as "Locked by another application." This webcam problem can be corrected by installing a Windows Hotfix, which is also included in Vista Service Pack 1 (SP1). Webcam Problems After Upgrading Windows Vista
Toshiba Satellite laptop owners may opt to use the Microsoft Anytime Upgrade to upgrade to Vista Ultimate. After doing so, the Chicony webcam may stop working and report a "Please turn on the camera" error message. Users can correct this problem by reinstalling the Chicony driver. b> Webcam Problems on Linux b> Linux users who own Toshiba laptops with the Chicony webcam should install the Linux UVC Driver to make the webcam functional. The webcam may not work without this driver. b> Grainy or Blurry Webcam Image b> The Chicony webcam can produce grainy or blurry images if the user does not remove the protective film that covers the external webcam interface.
http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions this will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps
b>
Jan 20, 2013 | Toshiba Satellite Computers & Internet
Hp elitebook 6930p webcam not working
LOL, yeah it's plugged in, but probably not compatible with Windows 7. You need to search HP's website for a windows 7 webcam driver for your model computer or you need to try getting it from Chicony's website.
Get onlineand got to www.google.com In the google search box type: "HPSupport" or "Chicony Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.You might also try Driver Guide for a Chicony Windows 7 driver at:http://www.driverguide.com
May 06, 2012 | HP EliteBook 6930p Notebook PC
Inverted web cam display in asus k401j
1. Download the latest Chicony (or Suyin) driver for Windows 7. Check here: http://support.asus.com/Download.aspx?SLanguage=en&m=Camera&p=3&os=)
2. Extract contents to desktop.
3. Click the ORB button. right-click on Computer and select Properties.
4. Select Device Manager.
5. Click on Imaging Devices to show the name of the webcam.
6. Right-click on the name of the webcam and select Properties.
7. Go to the Driver tab. click on Update Driver. a new window should pop-up.
8. Click 'Browse my computer for driver software'. select 'Let me pick from a list of device drivers on my computer'.
9. On the next window, it'll give you the current driver. click 'Have Disk'. click Browse. Browse to the desktop and select lastest driver that you've downloaded. it'll be then added to the list of drivers. select the new driver and click Next. Just follow the prompts so that it'll install the new driver.
If still this does not work, try this:
Re-install the camera virtual camera using your ASUS hardware disc and follow this step.
1.Insert ASUS hardware disc and "open"
2.Click "explorer"
3.Click "software"
4.Click "camera", then choose and click chicony folder
5.Open the folder APPLICATION/installer, and re-install the ASUS virtual camera.
Once you already installed the driver, go to start menu click or type ASUS lifeframe then open it.
Jun 25, 2011 | ASUS Computers & Internet
Webcam problem
Acer drivers.
I found this driver: Acer Extensa 5210 Chicony Webcam Driver 5.7
(I have also mirrored the file here.)
Here are the exact steps I took.
1. Downloaded the file.
2. Unzipped it to a folder on my desktop.
3. Ran the "Setup.exe" file in the folder that got unzipped.
4. Went through the installer until it got to the end and then let it restart my computer.
5. Waited for my computer to restart.
6. It popped up something saying it was installing the drivers for my webcam. Waited until it was done.
7. Opened the Control Panel.
8. Opened the Device Manager.
9. Find my webcam under "Imaging Devices". I noticed it was listed as "HP Pavilion Webcam"despite having just installed the Acer drivers.
10. Right-clicked on my webcam and chose "Update Driver Software..."
11. Chose "Browse my computer for driver software"
12. Chose "Let me pick from a list of device drivers on my computer"
13. Unchecked the "Show compatible hardware" checkbox.
14. Scrolled down to the Chicony manufacturer.
15. Chose the "Acer Crystal Eye webcam.
16. Told it to install anyway when it asked me a question about installing that driver.
17. Waited for the driver to be installed.
18. Noted that my webcam was now listed as an Acer Crystal Eye webcam in Device Manager.
And that was it. It appears to work totally fine now
Apr 05, 2011 | Acer Computers & Internet
I have an ACER Crystal Eye integrated webcam that does not work. Checks of software and driver upgrades state I have the latest version. Check on device manager and webcam error code 10 appears. Solution...
found this solution online
Want to know what worked for me? Acer drivers.
9. Find my webcam under "Imaging Devices". I noticed it was listed as "HP Pavilion Webcam" despite having just installed the Acer drivers.
And that was it. It appears to work totally fine now! Again, I have my fingers crossed that it won't suddenly break again, but so far so good.
Forgot to note: This is on a DV6000T running Windows Vista 32-Bit Home Premium.
And here's proof: smile.gif
I took that with Dorgem, an excellent, free, open source webcam application.
Oct 30, 2010 | Computers & Internet
Hey, excuse me... I need assistence imediatly. :-) because my PC camera wont start. Thanks
Hi my friend,
You didn't write your operating system. If your device is not out of order and set up correcly and doesn't work, then you may need its driver for your operating system.
I uploaded the driver of Chicony DC2110 web camera for the operating system Windows 98/2000/ME/XP compatible.
If your operating system is one of the systems mentioned above, you can download it from here. Find the file named "Chicony DC2110 Webcam Driver.zip" in the list and download it.
For windows 2000/ME/XP operating systems you will not run setup file. The driver will be installed in plug and play mode. Latest versions of operating system will recognize your driver when you plug in the device.
First un install your current driver.
Plug in you web cam and restart your computer. When operating system asks for the driver, select the \Driver path of the unzipped driver files that you downloaded and extracted in your PC (the default folder name will be "...\Chicony DC2110 Webcam\DRIVER").
If you need help, please send your comments.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 15, 2010 | Chicony TwinkleCam DC2110 Webcam
Where can i download my wc driver DC-6120
Panda 9B = Chicony DC-6120 or Icam 6120
Product page: http://www.chicony.com.tw/products/PCC/panda9B.htm
Drivers page: http://www.chicony.com.tw/download/kb/top1.asp (note that this model is not listed in the drivers download page. This driver doesn't seem to exist anywhere). Try the Model 6110 driver...
Oct 04, 2009 | Computers & Internet
Built in webcam e525 doesn't show up in control panel
i have the same problem and acer arent very good wither they just told me to ring a number is your laptop on windows 7 as well becuase its frustrating me very badly. >:/ have you found a solution if so let me know
Sep 04, 2009 | Acer Computers & Internet
Driver for integrated webcam
This driver should according to website work for both Vista and XP. It seems to be the latest on the web that I was able to find. The Bison driver on the Fujitsu-Seimens website worked only for Vista.
Your camera according to Fujitsu-Seimens is a Chicony 6133 internal webcam using the Bison driver which is already highlighted above.
One small Fixya as compensation would be nice if it works for ya and I hope it does as some of these company websites are stingy with information.
Aug 30, 2008 | Computers & Internet
Chicony USB 2.0 Camera: NEED HELP!!!!!
Follow these steps to re-install the driver for the webcam. You will need to be logged in as an Administrator or have an Administrator password ready.1. Click the Windows Start button.
2. Click Control Panel, System and Maintenance and then Device Manager.
3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver
4. Select Browse my computer for the driver software.
5. Select Let me pick from a list of device drivers on my computer.
6. Select USB Video Device from the list, and click Next.
7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close.
8. Restart Windows.
The webcam should now work properly
May 24, 2008 | Computers & Internet
Open Questions:
Toshiba Satellite A305D-S6848 Notebook Logo
387 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
