Question about Toshiba Satellite A35-S159 Notebook
It wont turn on evin when it is plugged in to the charger
    Sergeant:
    Champion:
  • 240 Answers
OK this sounds daft but before you try anything else-unplug it-remove battery-leave for 10 mins then replace battery. Sometimes this works! It certainly won't do any harm.
Posted on Oct 03, 2009
    Problem Solver:
  • 3 Answers
Have you try to get new plug have you look at the fuse in your plug have you got new cable in case it that...
My Nextbook wont turn on
Although it is not recommended for normal operation, try turning it on with the charger plugged in. If this works, check the battery status indicator. If it shows a full charge, try disconnecting the charger. If the Nextbook quits working, the battery is bad.
If it does not turn on, try holding the power button for five seconds, then while holding the power button on, plug in the charger and continue holding for five seconds. If nothing happens, release and press the power button again with the charger still plugged in. (This may reset the internal power management chip.) Also, try the recessed reset switch (see your owner's manual).
If none of this works, verify that the charger unit is good. The simplest and safest method is to measure the output voltage on the output plug with a digital multi-meter while the charger is plugged into an AC outlet. It should be within 5% of the nominal output voltage on the charger label.
The most common power problems are battery failure, broken charger wire (usually next to the plug or the power conversion box), or broken charger jack in the unit.
Jan 10, 2012 | Office Equipment & Supplies
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
Dec 16, 2011 | Sanyo SCP-2700 Cell Phone
Laptop wont start at all. plug in to power supply and battery charging light comes on.still wont start up...
try diconnecting the charger and holding down the power up button for longer, then try plugging in charger- turn on charger at wall then hold down power on button till power button on key lights up, i hope this helps you out ;)
Feb 07, 2011 | Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
My coby mp3 player only work while charging.
the power switch is fragile - if you break it then you cannot turn on the player. plugging in the charger will turn it on but only while the is power coming from the charger.
Dec 26, 2007 | Coby MP-C7085 MP3 Player
Razr wont chage
GO TO SETTINGS" .... SCROLL DOWN TO "PHONE STATUS" AND CLICK ON IT. iF IT SHOWS "DEAD" BUT YOUR PHOPMR STILL POWERS UP ... YOU HAVE A FEFECTIVE CHARGER, ALSO ... TRY DRAINING THE BATTERY. THEN SHUT THE PFONE POWER OFF FOR TILL THE CHARGER IS COOL TO YJR TOUCH. LEAVE YOUR PHONE OFF AND PLUG THE CHARGER IN FOR 3-4 HOURS. oNE OF THE TWO SHOULD TELL YOU WHAT IS BAD
Jun 30, 2007 | Motorola Mobility RAZR V3
Toshiba Satellite A35-S159 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
