Question about Kodak EasyShare M883 Digital Camera
When the camera is turned on it shuts off with plenty of battery power showing I have wiped the leads on the battery with a cloth also Thanks
Turns on for 2-3 seconds shuts right off battery is ok hp 707 pho
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. "Very Helpful" would be appreciated . .
Dec 06, 2009 | HP Photosmart R707 Digital Camera
Camera shows that battery is low even when changed to new ones and shuts off.why?
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 30, 2009 | Fuji FinePix A205 Digital Camera
When i turn on my camera, it shuts off right away. the battery is fully charged and it stills shuts off.
Nov 21, 2009 | Kodak EasyShare M1033 Digital Camera
CAMERA WON,T TURN ON BATTERY HAS PLENTY OF LIFE LEFT
Oct 24, 2009 | Kodak Easyshare M753 Digital Camera
Stylus 7010 keeps shutting off battery fully charged. Turn on, access card light flashes then shuts off
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may require professional repair.
Oct 17, 2009 | Olympus Stylus 7010 Digital Camera
I purchased a GE Z735 digital camera that turns off
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Both problems will cause the camera to shut off in order to prevent further damage, and both require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Cameras
CAMERA WILL NOT STAY ON WITH NEW BATTERIES.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera.. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your camera has a problem that requires professional repair.
Oct 12, 2009 | Samsung Digimax D53 Digital Camera
My camernot shut on or off. Its like its stuck.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 27, 2009 | Kodak EasyShare One Digital Camera
My camera shuts off when i try to zoom.
Here are the steps:
clean cloth.
Thanks.
neerak21
Sep 17, 2009 | Kodak EasyShare V1073 Digital Camera
My camara wont turn on
Here are the steps:
Thanks.
Neerak21
Aug 27, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M883 Digital Camera Logo
103 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
