Question about Onkyo HT-S680 System
Onkyo HT-R430 AV Receiver not turning, same issue I have seen posted twice. Comes on for a few seconds and and goes into standby.Tried reseting the power and taking batteries our of remote control. Anybody know how to fix this issue..... bayareaz5z@yahhoo.com Thanks
  • slscpoe Dec 22, 2007
    Dude I have the answer
nenalex2002
  • 134 Answers
SOURCE: remote control codes
Here is a link for the complete manual :
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
remote codes start page 61
To control an Onkyo receiver with a universal remote try code 0135
Hope this helps
Alex
www.CustomAutomaticSystems.com
Posted on Nov 11, 2007
SOURCE: Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Posted on Dec 22, 2007
SOURCE: Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Posted on Jan 01, 2008
You might have blow the fuse for those channels.
Posted on May 05, 2008
petraman7
  • 1175 Answers
SOURCE: power cord cut can it be fixed
HI...
Is the power cord the type you can unplug from the unit?
If so, go to radio shack and get a new one.
If not , do something like KNtech said but if you cant solder , you can use 2 wire twist caps that connect wires together.
Go to a hardware store and show them what needs to happen and they can help.
Posted on Feb 08, 2009
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
How to reset reciever
If you can't resolve the issue yourself, try resetting
the AV receiver before contacting your Onkyo dealer.
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. "Clear"
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
Mar 17, 2013 | Onkyo TX-SR606 Receiver
I have an Onkyo AV Receiver HT-R500 and when I turn it on, it turns on and in less than one second it turns back to standby. What could be wrong?.
Try disconnecting all the speakers and see if it does the same thing. If it doesn't, connect speakers again one at a time to find out which one of them is doing it. Make sure the speakers rating match the output of the amp.
Jun 16, 2011 | Onkyo HTR500 Receiver
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
Receiver display started scrolling fast through set-up options on it's own and then stopped scrolling with "V1 PLX Movie" in the display and none of the front panel buttons including the power switch have...
Try this, but you'll lose any presets and setups.
press the [STANDBY/ON] button. “Clear” will
Standby mode.
Jun 09, 2010 | Onkyo HT-S790 Home Theater System System
Have ajustments all screwed up
If you can’t resolve the issue yourself, try resetting
button, press the [ON/STANDBY] button. “Clear”
enter Standby mode.
Feb 10, 2010 | Onkyo HT-S9100THX 7.1 Channel Receiver and...
The receiver cannot be turned off and none of the buttons work anymore.
I used to work on home theatre systems have seen this issue before. What most likely happened is there was a storm or surge in your area and it hit and damaged the microprocessor. If your unit is still under a warranty its best to send it in for repair. Otherwise it can be an expensive repair. However before you call or send it in for repair try resetting the AV receiver by holding down the [VCR/DVR] button and pressing the [STANDBY/ON] button. if this does not work it needs to be sent in for repair
Jan 27, 2010 | Onkyo HT-SR800 System
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
Nov 12, 2007 | Onkyo HT-S680 System
Onkyo HT-S680 System Logo
288 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
