Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
Runs 1 minute, gets hot and shuts off help!!??
Runs 1 minute, gets hot and shuts off help!!?? wiring for 220?
  • 291 Answers
Need a bit more information.
Are you saying that you have set it up for 220V or that you are running it on 220V?
Many motors can run on either 120 or 220, but you must check the leads and make sure they are jumpered correctly.
Are you running on 220 or 120?
Are there leads with numbers in the connection box that have wire nut or jumpers on them?
Posted on Oct 03, 2009
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
How do I wire a Polaris PB4-60 in the USA (115V)?
I am not sure if this will help you out any, but here goes:
Line1 & Line 2 are your Hot Power Wires coming into the motor.
It does not really matter which wire goes to which post of the motor.
This will remain true if you are bringing in 110-115-120 (these are all the same, people just refer to them differently) which also is referred to at times as "Low" voltage, and the same goes for 220-230-240 (again, referred to differently) which is referred to at times as "High" voltage.
Whether bringing in Low voltage or High Voltage, the wires you bring in will number only three:
  • Ground
  • Hot
  • Hot (potentially Hot)
Low Voltage (115) will have:
  • 1 Absolute Hot Wire = Line 1. Normally Black
  • 1 Potentially Hot Wire = Common/Nuetral Line 2, normally White
  • Ground/Earth = Normally Green
High Voltage (220) will have:
  • 1 Absolute Hot Wire - Line 1, Normally will be same color as Line 2 or Black/Red
  • 1 Absolute Hot Wire - Line 2, Normally will be same color as Line 1 or Red/Black
  • Ground - Green
In either of the above voltages, it does not matter which wire goes where, as long as a Hot wire goes onto Line 1 and the other "Hot or Potentially Hot, if 110", goes onto Line 2. Do not put a Hot wire anywhere else and Do Not put a Ground wire on either Line 1 or 2!
Most Motors are coming out of the factory wired for High Voltage Set up (220), so you will have to move some wires or a terminal block, to set the motor to operate at "Low" voltage (115). These motors are "Dual" Voltage, they have the capability to run either 110 or 220. But they don't magically know which voltage is being supplied.
Good Luck
Jun 20, 2014 | Polaris Pb4 - 60 Booster Pump
New motor and it overheated afterr 15 mins and shut off
make sure on side of motor is wired for 220 volt 1 hot to L1 2nd hot to L2 green to ground
Jun 08, 2014 | Smith AO Pool Pump Motor
Cannot get my generator to run on 220 mode, only runs on 110 when I disengage the auto throttle
There's a short in the 220 circuitry. Check for continuity between the two hot leads, or between the hot leads to ground
Jan 25, 2014 | Honda Electrical Supplies
1994 fxstc gets hot after running about 15 minutes
Hi Anonymous, and the usual suspects are:
1. Insufficient oil supply or oil not circulating.
2. Insufficient air flow over the engine.
3. Heavy carbon deposit in combustion chamber.
4. Ignition timing retarded due to faulty MAP, CKP and/or CMP sensors.
5. Leaking intake or exhaust valve.
6. No oil cooler.
7. Normal engine oil tempurature 180-220 degrees.
Good luck and have nice day.
Mar 24, 2012 | Harley Davidson Motorcycles
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
My saw is wired for 220. I inherited it and
first of all if moving backwards it will get very hot.
Reverse the two 110 wires to make it run clockwise. it should run cooler as well running the correct direction
Feb 27, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Have a 1991 Jacuzzi 2 HP 220/110 pump. need wiring help
If you are running a 120 volt line then there is no way it could run 240. Did you wire it yourself? A 240 would have a hook up in the box for a red hot wire, a black hot wire, a white neutral, and a green or copper ground wire.
A 120 would have a white neutral , a black hot, and a green or copper ground wire. It wired correctly, you may need to replace the capacitor. But be certain you have cut the power to the circuit off at the panel.
Jun 04, 2009 | Home
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
237 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
