Question about Motorola Mobility ic902 Cellular Phone
External buttons no longer work. Nextel button sometimes works after pressing repeatedly, likewise the speakerphone button. Volume control UP button sometimes works, DOWN never works. I'm guessing the contacts are corroded or simply dirty but how to clean?
These may be the a few of the possible problems:
1. the phone has been dropped, and the logic board has malfunctioned 2. your possible idea (contacts are dirty)
if you wish to clean it, i can't really help you with that. not a hardware type of guy. however if you bring it to a nextel store, they may get you a new phone if your contract is up, or give you a replacement. Just mention it's sort of defective and happened on it's own if you didn't drop it or anything
Posted on Nov 07, 2009
Magnavox 32mf369b/f7 sound occasionally decreases by itself, as if someone pressed the button
The volume button must be smashed in,dirty,or defective...I would try pressing the volume- several times repeatedly..maybe try cleaning it with a can of air.
Nov 28, 2012 | SNK Magnavox 32MD357B_37 32 in. LCD...
Volume does not work on television
Check the batteries.
If you have a digital camera, camcorder or camera phone, turn it on and point the remote at the camera lens. Press the volume buttons on the remote. You should see a flash on the camera lcd screen. If not the buttons on the remote are not working.
Check the buttons on the side/top of the tv to make sure the tv volume is working.
If the remote is dead, sometimes doing the following steps may restore it.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Feb 15, 2011 | Samsung TV Remote Control
Starting this morning I can no longer hear any volume on my voicemails, either through the speakerphone setting or normally. Phone calls work just fine. Voicemails appear to be saving fine, I just can't...
it may sound stupid, but i had that happen too. I had use the side volume controls to raise the media volume, depending on when you press the volume button it will adjust the ring volume or media volume. Press the button while the msg is playing.
Apr 04, 2010 | Motorola Mobility CLIQ Cell Phone
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
My sky remote control has recently stopped turning my tv on and off and also controlling the volume. I have encountered this problem before but after a day the problem has righted itself. My tv is a JVC....
Hello Rina
Please follow the steps below with the sky remote:
TV
RED + SELECT
TV
0053
press the volume button if this works press the SELECT button to save if not press TV then volume again. repeat this step until the volume works. Dont forget to press the SELECT button to save the code.
Hope this Helps
Cheers
Little Dish Fitter
Sep 18, 2009 | Televison & Video
My volume and mute button dont work on my sky remote
panasonic
please follow the steps below:
TV
RED + SELECT
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 06, 2009 | Universal Remote Control Remote Control
Can't hear other person when i put my razor on speakerphone
How do the external buttons work on my device?
space.gif space.gif answer.gif gifadjust your volume key.
Oct 22, 2008 | Motorola Mobility RAZR V3
Broken buttons
Take the phone into a mobile shop and ahve them fix the phone for you
Jul 09, 2008 | Samsung SCH-u740 Cellular Phone
How can i reset my nextel i 930
keep the nemu button pressed while phone is off then press power button it will ask you "press ok to format" and voila done new phone and password reset.
Apr 01, 2008 | Nextel i930/i920/i870 Stereo Headset [OEM]...
Parrot memory full
I had same problem too.
I have googled 3 days and found the solution from MULTICAN manual.
•Reset the hands-free kit:
Repeat the following sequence five times:
press the "Volume (-)" button and then the "Volume (+)".
And also F.Y.I.
•Enter the menu:
Press the following sequence twice: [SEEK up] button then the [SEEK down] button.
•Go forward through the menu: Press the "Volume (+)" button.
•Go backwards through the menu: Press the "Volume (-)" button.
•Select a menu option: Press the "Phone" button.
•Cancel a function: Long press of the "Phone" button.
Jan 18, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Motorola Mobility ic902 Cellular Phone Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
