Question about LG DLE2532W Electric Dryer
Getting back off
How do you get the back off of an LG 2526W gas dryer?
    President:
  • LG Master
  • 1,922 Answers
You dont, you start by removing the front cover, then you'll see the screws to remove to take top cover off,then remove drum belt and drum and your inside the unit
Posted on Oct 09, 2009
How can i tell is thermostat on exhaust pipe on my LG gas dryer, model DLG3788W, has blown? Button is sticking up...
Hello & Welcome to FixYa
You can test the thermostat with the voltmeter...if it tests open then replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 24, 2011 | LG DLG3788W Gas Dryer
LG DLG 2526W dryer running but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 22, 2010 | LG D2526 Gas Dryer
How do I get the back of a LG Dryer DLG0452W off?
You cannot get the back off. You work from the front.
Remove the top first by getting the rear screws off then remove the controls and top front brace then remove the drum glide then the take the belt loose and lift out the drum. You will now be able to examine the motor.
May 03, 2010 | LG DLG0452W Gas Dryer
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
I have an LG Gas dryer. Almost daily no heat is
Check your exhaust duct - the long tube that goes from the back of your dryer to the vent outside. It may be clogged with lint.
Oct 08, 2009 | LG DLG5988 Gas Dryer
I'm trying to find out how to get to the fan moter in my dryer.
if you have to go thought the back try that then its a belt or you motor
May 01, 2009 | LG DLG5932W Gas Dryer
LG GAS DRYER NOT LIGHTING THE SECOND TIME AFTER COLD START. IGNITOR COMES ON: SENSOR SEES IT IS HOT ENOUGH AND GAS VALVE OPENS. FLAME COMES ON THEN GOES OFF WHEN TEMP IS REACHED BUT WHEN DEMAND FOR THE...
If your vent is clear (strong flow of air at vent outlet outside) then you have a bad gas valve. I have seen this a few times on LG gas dryers. You really only need one of the coils on the gas valve, but they are not available individually. You have to get the entire valve.
Oct 28, 2008 | LG Dryers
Conversion back to natural gas
4948EL4001B back to natural part number LG will only sell it qualified techs..but here's a start.
Jul 09, 2008 | LG DLG3788W Gas Dryer
Lg 7188 gas dryer conversion to lp
How do you get the front off a LG gas dryer
May 02, 2008 | LG DLE5977 Electric Dryer
LG DLE2532W Electric Dryer Logo
161 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
