Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Lights on pots and pans blink constantly
Several lights on front of dishwasher come on and stay on. the pots and pans light stays on all the time and the others will go off after a while.
    Novelist:
  • 148 Answers
Try disconnecting power for a bit. try the cord under the sink. if its hard wired (no cord) you can try the breaker.
may reset itself.
otherwise, you have a logic board issue.
consult the manual first for explanation of blinking lights etc.
then call the mfg for further info and if needed, schedule an approved repair person.
good luck
mark
Posted on Dec 28, 2007
The pots and pans light and normal light is blinking
Kenmore Elite Dishwasher blinking light Control Board FIX ...
? 1:37
www.youtube.com/watch?v=flzhfmIIYpM
Apr 14, 2011 - Uploaded by MegaHowtoMan Kenmore Elite Dishwasher blinking light Control Board FIX ....year old washer, did a google search for the problem, and your video came up.
Sep 01, 2015 | Dishwashers
Key stuck on
Your description of the problem is a little vague.... What light(s) stay on? What light(s) flash? Is there a pattern to the flashing lights, in other words, does it blink so many times, then pauses, and repeats? Ir does it just blink steadily, continuously? And how about a model number or approximate age of your dishwasher?
Jan 09, 2012 | Kenmore Dishwashers
When I turn on My RCA L40fhd41 40" television, the LCD screen constantly blinks on and off like a strobe light. The power light stays on constantly, but the screen continues to blink
Dec 12, 2010 | RCA L40FHD41 40. in HDTV
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
Pots and pans and normal lights blinking
That reset sequence code didn't work for me. We tried everything on a ton of forums.
What I did to fix our Whirlpool dishwasher was to disconnect the drainage tube from the garbage disposal. I noticed it smelled really bad so I figured it was clogged. I used a bucket to catch the water left in the tube. I took the sprayer from the sink and flushed out the tube. 4 pumpkin seeds and a couple of beans landed in my bucket. I flushed it a couple times. I hooked the tube back up to the disposal and sure enough all the lights returned to normal. I pressed start and it came on.
Feb 22, 2010 | Whirlpool GU2200XTSB GU2200XTSQ 24 in...
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
Blinking lights on Front Panel
I've finally tracked down the manual and it the fault code is as follows
"Indicates a fault in the heater or in the thermistor"
You can go into a fault tracing mode by pushing the "Rinse Hold" button five times within 15 seconds. The first, third, fifth and seventh lights will flash when in this mode and you can test the following parts by pressing the corresponding button. I'm going to try the heater test below and assume that if that works the fault must be with the Thermistor. The other tests could be useful for other faults.
User manual found here
Rinse Hold - tests detergent solenoid, detergent flaps open after about 60sec
Pots & Pans - tests Rinse Aid Solenoid, rinse aid will flow down door
Normal Wash - tests water inlet valve, water can be heard entering
Light Wash - tests ventilator solenoid, there will be a click followed by a rattling noise
Quick Wash - tests the heater, the element heats up, WARNING don’t touch element HOT
Temp - tests circulation pump, the pump starts
Dry - test outlet pump, the pump starts
Manual says to push 55 and 65 degree button to exit, I have no idea where those are so will probably just switch off at wall to reset.
Hope this helps someone. I rang ASKO and they said they didn’t know what the fault code meant so either they can’t read or their service sucks, probably a bit of both!
Feb 12, 2009 | Asko D1716 Built-in Dishwasher
I have the kitchenaid dishwasher model #kudv03ctss0.the clean light stay blinking and when i hit the start it just blinks and then stops but the clean light stay blinking constantly.if i hit the cancel...
Dear friend,
ngfam at you service! happy to assist!
It's an electronic problem!
The lights are called codes and need to be diagnoed by a factory service person!!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Dishwashers
Flashing pot and pan light
shut off the power and see if the unit will reset. if its plugged in, it will be easy, look under the sink. if not, try a breaker.
let the power stay off for about a minute.
then back on.
if not restored, then you have logic boards that failed.
sorry,
good luck
mark
Oct 24, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
185 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
