Question about Gateway Computers & Internet
My EasyCap has 'Malfunctioned', I got it yesterday to record my Xbox 360 and it was working fine, apart from the Ulead VideoStudio (I was using Amcap), but now when i plug it in to my laptop it says the ''USB device is not recognised'' and that it has malfunctioned. I have tried to un-install everything and then re-install it but that didn't seem to help. I'm not sure which model it is, on the instruction manual thing it says EasyCAP 003, 006 and DC60+
SOURCE: EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Posted on Feb 16, 2008
SOURCE: Problem in Capture
I don;t know if this is the solution to your problem but it might work, as it did for me.
When you start ULead Studio click on the capture tab, then click on the camera icon named "capture video", then in the middle of the page you will notice the "options" icon (looks like a cog) go to Input source and then at the top of the window you will see "input source" again, click the dropdown list and select "video composite". Try that and see what happens.
Posted on Mar 10, 2008
SOURCE: EasyCap & Ulead
as far as i think that ur graphics cards is not supporting ur and ram is to less and ur hard disk plze see thee details and i think that u shuld ur os and ur syestem cong. plze see this
Posted on Mar 28, 2008
SOURCE: EasyCap DC60 Vista 32 bit Driver
hi : i get the same problem but i solve it ............ how ?
i uset tow kind of cables in the same time : the svedio cable and the av cable
from the source connect the svedio normally to get a vedio and the av
cabe tow of them : the red and the white in their same color jacks .
to the easycap connect the svedio normally and the red av to the red and the white to the white and leave the yellow
but unfortunetlly this way work vey perfect withe me only on widows xp sp3 and im still keep trying to make it work on vista .
good luck to all .
Posted on Jul 04, 2009
  • 8 Answers
SOURCE: can't find Easycap DC60 video002 USB 2.0 DVR
If it is a driver that came with the computer you could go to hp.com and go to driver downloads to find the driver.
Posted on Jan 05, 2010
I don't have the cd disc to install the softwear of EasyCAP, computer is asking for the driver cd.
To get software driver of easycap gadget click the following link http://www.usbeasycap.info/support.html
If finish downloading, double click software driver, before connect the easycap gadget.
Hope can help you.
Regards
Jul 16, 2011 | Computers & Internet
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
Trying to capture clips from Xbox 360 via PC
http://www.produktinfo.conrad.com/datenblaetter/950000-974999/956875-an-01-en-Quick_Installation_EasyCAP_VideoAdapter.pdf
Apr 07, 2017 | Ulead Videostudio 8 for PC
Ulead 11 with EasyCap on Windows Vista
souds like you have not selected the correct video type - try all the diff Pal ones
Apr 08, 2009 | Televison & Video
XBOX 360 NTSC only Black and White
yes xbox 360 NTSC only in black and whit colours
Feb 06, 2009 | Ulead Videostudio 8 for PC
EasyCap usb adapter sending images only from vcr. No sound.
while i preview mode there is no sound only image. when you record then playback sound is there.
Sep 16, 2008 | Ulead Videostudio 8 for PC
Easycap software
noavatar_s.gif j_whitmill Nice SPAM for your stupid pay site loser! Kill his account!
May 26, 2008 | Adobe Photoshop 7.0 for PC
Audio in EasyCap/VS10
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly.
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound. Although I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Hope this helps!
Mar 07, 2008 | Ulead Videostudio 8 for PC
Computers & Internet Logo
218 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
