Question about Dryers
Blows cold air no water light on just not heat
My dryer stop producing hot air, looked at heater element does not look burnt out, can anyone advise me on what to do as i looked at web advice saying to reset on a reset button but can not locate it where they are telling me it is.
i would be very grateful xx
  • Dryers Master
  • 7,482 Answers
Disconnect/Unplug your power going to the dryer, then disconnect the two wires from the heating coil and use a continuity meter across the terminals to make sure it is not burned out.You should have continuity across the terminals. Sometimes just looking at the heating coil is not enough.
If it is ok, the the problem might be faulty a thermostats.
Depending on the make of your dryer you may or may not have a reset button. If you do it will be in plain sight when you remove the back of the dryer.
I hope this helps
Posted on Oct 03, 2009
Why is my Panasonic's czrtc2 blow cold air out of vent went heater turns off
A fan heater is a fan blowing over a bank of electrical elements, or in many cars, hot coolant water is directed through pipes in the heater assembly, in place of electric elements.
In any case, if fan is still running when heater is turned off, the source of the heat will be gone, so blowing only cold air.
Dec 04, 2017 | Cars & Trucks
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
My machine has stopped producing hot water. The lights don't even flash to show it's heating up when I switch it on, it just goes straight to ready mode & then when I brew some coffee it comes out...
Either your coffee boiler elements are damaged or the thermostats on there are damaged or tripped, use an ohms meter to check element and thermostats.
May 20, 2010 | Gaggia Syncrony Compact Coffee...
No heat only cold air
Heater element burnt out. Need to replace the heater element. If heater element is not on, the blower only blow cold air.
May 04, 2010 | Dryers
Dryer blows air, but no heat - the dryer powers on, the drums turns and the fan blows air, but the air isn't hot.
There is one of two possibilities:
1.-The heating elements dont come on due to a wire burnt off or the element itself has burnt out.
2.- There is a small electronic device in the element circuit called a thermal overload switch, which has and often does malfunction, stopping the power to the elements.
Best wishes,
Graemevm
Dec 17, 2009 | Office Equipment & Supplies
Blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
Apr 15, 2009 | Dryers
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
ZANUSSI TC7103W
There is a thermostat inside the machine just inside and top, put your head in and look up. Took my whole machine apart before finding the wire which led to it!! It should be Normally Closed (NC) and cuts the power to the heating element when too hot or broken! Hope this helps.
Bolts
Mar 28, 2007 | Zanussi TC7114W Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
