Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
Moen 87135c - cant take apart
I have a moen 87135c kitchen faucet (or similar) that is leaking - looking to change the cartride, the O rings, just tighten or all - but I can't figure other way to get it apart - I don't see an allen wrench socket or other way to unscrew it - what am I missing?
  • kimizzyjack Oct 04, 2009
    OK so I got it apart - thanks very much- replaced the cartfidge (Lowes didn't have O rings) and put it all back together - but it still has a leak - I guess I should try the O rings -
    Does o-ring replacement involve diconnecting water hoses in order to get under the spout? Wondering if its better to replace the whole faucet at this point
  • 129 Answers
On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
Posted on Oct 04, 2009
Testimonial: "thanks - i saw it there but didn't see the set screw - now if i can only find the right size allen wrench -standard US doesn't fit!"
Replace o rings on a moen adeline model 87787SL KITCHEN FAUCET
How do I remove the faucet Moen model 87787 to place O-rings?
Jan 30, 2013 | Moen Plumbing
Need to replace O Ring but cant pull the spout off
there might be a allan screw holding it down usually located at the back of the faucet if not there is a chance that there is a screw on escutcheon just above the base of the spout this should screw off with a strap wrench.
Aug 24, 2012 | Moen Monticello Single-Handle Kitchen...
7700 series Moen leaks at top and bottom of base hub
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
The replacement o-ring and retainer parts were free to me. Hope it helps you.
Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Our jameco kitchen faucet has no water pressure. also we have a slow leak on the cold water side. The faucet is only 3 years old. we took the cold side apart and there is no washers, only an o ring that...
Sounds like you may need to replace the cartridge if you have one of the late model single control models. You may get a clue as to how your faucet might be put together by finding a similar faucet on the Moen web site, and looking at their exploded parts diagram. (They are good about posting information; although some say their products are not so good; I really don't know personally)
Dec 14, 2009 | Delta 2402 Classic Single Handle Kitchen...
Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
Moen 87135C leaks - I've replaced the cartfidge (Lowes didn't have O rings) and put it all back together - but it still has a leak - I guess I should try the O rings - Does o-ring replacement involve...
If you call Call: 1-800-BUY-MOEN (1-800-289-6636)
8:00 am to 8:00 pm Monday thru Friday
8:00 am to 6:30 pm on Saturdays EST. and give them model number they will send you the parts.
Oct 04, 2009 | Moen & Replacement Cartridge
I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Aug 30, 2009 | Moen 87555C Trianna Single Handle Pulldown...
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
693 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
