Question about Kodak EasyShare Z612 Digital Camera
MY camera seems to be overexposing all pictures taken , so that I can not take outdoor photos at all and can only take photos inside if I close the drapes and block all natural daylight. It seems as if perhaps a settings button has been accidently hit or something...NOT SURE but I do not see how to fix it.
  • pbedford Oct 03, 2009
    How do I check ISO setting? I went to the menu and do not see anything that indicates the ISO setting.
  • 125 Answers
Hello, the problem that you explain could easily be caused by an improper "ISO" setting. When you go to your camera's menu, look for the ISO setting and put it back on "auto". It's probably on 800 or higher now, which will cause everything to be overexposed.
Posted on Oct 03, 2009
  • collegetutor
    collegetutor Oct 22, 2009
    I believe that you are not looking in the right menu area. Those camera have a menu on the side of the viewing screen when its turned on. It's possible that you have 'on screen' menu turned off and you are looking in the system menu instead of the settings menu for current photograph. Turn on "on screen' display or menu and once you do that you should see your options for the current photograph, such as whether to turn on your flash or not and whether to focus for macro or infinity distance, etc. I hope this helps a bit more. Those camera menus can be a bit daunting at first, especially if you don't have the manual. But the manual should be available for download from the Support pages of the Kodak website under the model number of your camera. Have you tried that?
Www samsungcamera com
It seems to me that the camera is overexposing the images.
First make sure that the 'ISO' is set to a lower value such as 100 or 200. Also ensure that the Exposure Compensation (+/-) is set to '0'. For this, you might need to put the camera on 'P' mode.
Aug 25, 2014 | Samsung L73 Digital Camera
All outside pictures come out very white. Inside seems to be okay. Have tried 'reset' but still no good.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 04, 2011 | Casio Exilim EX-S600 Digital Camera
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
May 29, 2011 | Samsung S1070 Digital Camera
The screen of the camera works only for setting and menus, but for shutting photos the screen is black. No more photos could be taken. I seems to be taking photos but all of them are black. But I heard...
And here you go, this should help. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 29, 2010 | Canon PowerShot S2 IS Digital Camera
My camera cant photoshoot on outdoors, everything that captured looks white. When I photo shoot in our house -- dark room, it seems fine, but WHITE HORIZONTAL LINES appear? I've already used it about 3...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, recommend trying the pencil tapping method described in this article for a stuck "open" shutter.
Jul 31, 2010 | Canon PowerShot A470 Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
Outdoor images overexposed
hi, its a problem of lence flap,it is in the lence berral , just change the lence flap and your camera is ok,remember if you are a tecnition then try your owen
Aug 27, 2009 | Sony Cybershot DSC-T200 Digital Camera
The pictures I take outside are white.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Optio S5I photo's outdoor are overexposed
Your lens shutter is not closing, causing the overexposure. Your lens will need to be replaced or rebuilt. Sorry.
Nov 12, 2008 | Pentax Optio S5i Digital Camera
Casio exilim EX-S500 overexpose
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
also, did you ever try cleaning the lens?
May 25, 2008 | Casio Exilim EX-S600 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
209 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
