How to retune my swisstec dvb t freeview tv
2 Suggested Answers
  • 53 Answers
SOURCE: after retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Posted on Nov 06, 2009
Does the tv model sylvania tvk191 have a qam tuner?
If the TV is sold in the UK, then yes it has a QAM tuner.
All TVs have to be able to pick up Freeview to legally be sold as a TV in the UK. Freeview is the public name for the DVB-T service which is our Digital Video Broadcast - Terrestrial service. DVB-T is just the standard definition channels. DVB-T2 is the version of Freeview that includes HD as well as SD channels. The QAMs are the way in which the signal is encoded. But it's really a level of detail that you don't need to go to. It's sufficient to know that the tuner is ether DVB-T for SD only, or DVB-T2 to pick up SD and HD.
Sep 08, 2014 | Televison & Video
Pink 19" Soundwave Widescreen LCD TV with DVD and DVB
When you retune your TV to freeview make sure you SAVE settings
Dec 15, 2013 | Televison & Video
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
Apr 24, 2011 | Televison & Video
How do you retune a swisstec tv after the digital switch over.i have been threw autosearch and the yellow bar apears.it looks like it has done it but gos back to the blue screen.
HI, does the tv have freeview?
If not you will need one and tune the free view box.
On my tv , when they turned the signal off i had to switch to the DVB section on the tv setup section, so without knowing your model number, I can't tell you what to do.
I hope this helps.
Regards - Anthony
Feb 08, 2010 | Televison & Video
HAVE GOT A SWISSTEC 15 INCH TV BUILT IN FREEVIEW, BUT CA NOT GET ITV 1 OR CHANNEL 4 ON IT. HAVE TRIED RETUNNING BUT NO GOOD
The model number would usually be on the back of the TV but in this case it's immaterial as Swisstec appear to have had a very brief existence. Their website no longer works (skymediamanufacturing.com, no connection to Sky satellite tv) and the few products which have their brand name on all seem to be at outlets like ALDI and Makro which often specialise in clearance lines and bankrupt stock.
First, check that your missing channels haven't been shifted to 801, 802 etc. This is happening with some equipment and it's just how some slightly incompatible equipment handles the retune.
What you have said about your aerial system does not eliminate the possibility of an aerial fault; as you're running multiple items off one aerial I'd fully expect it to be a high gain aerial, but this does not necessarily mean that it's a wide band aerial. In addition, each time the signal from a single aerial is split there is typically up to a 10dB loss (around 60% each time). Regular analogue reception equipment can cope with this far better than Freeview receivers as the analogue signals are vastly more powerful than the digital ones. One of the most important UK transmitters puts out a 100kW (i.e. 100 000W) analogue signal along with an 800W Freeview one making the analogue signal 125x stronger at the transmitter and far weaker further away.
Realistically, you have limited options. Most Freeview receivers have an onscreen menu in the digital tuner which has a signal strength and quality meter for each channel. If most of the channels have a middling signal with good quality then your reception is most likely ok so look at the aerial cable at the back of the set to see how long the plug into the back of the tv is. If it's longer than about 2cm then it probably has an in-line suppressor fitted onto the end of the plug. Usually there's a marking of either 6dB or 10dB on the suppressor. Remove any suppressor and try retuning.
If that didn't work then check as much of your aerial system as possible paying special attention to the plugs and splitters. No plug should be showing any bare wire, and the external screening braids must not be touching the internal signal wire. You'll probably have to undo each plug to check for this and remake any shoddy work. If you have aerial splitters which are the push together variety then check the connections are tight. Also consider replacing them with the screw threaded F-terminal splitters which all professional installers use. These cost very little more than the useless things sold in most DIY stores and general retail outlets but hugely reduce signal losses. I've posted an online address of a supplier at the end of my post, but you can also get them from your local Maplin store usually at extra cost.
If you have an amplified aerial then try disconnecting the amplifier. These are often inappropriately fitted and cause digital signal meters to show the confusing message of a strong signal with poor quality. A good quality weak signal can be successfully amplified but a poor quality signal requires a better aerial installation.
If you have eliminated all doubt regarding your aerial then the fault is most likely with the receiver itself. The official advice is to try retuning but you've almost certainly done that. There is a list of equipment known to have problems with the retune (see second web address) but it's not comprehensive and misses out minor brands like Swisstec. Clearly you cannot contact Swisstec and they are in no position to rectify the problem themselves any more. Under these circumstances your only remaining option is to buy a new external receiver from around £20 and connect it to your tv as if it never had an internal receiver.
Note that the UK Sale of Goods Act was recently amended to allow purchasers up to six years protection against goods which are not of "satisfactory quality" (replacing the earlier term "merchantable quality"). You've had your tv for eighteen months and the tv itself still works, but as a super-budget unknown brand it's doubtful that you could press your rights regarding the failed Freeview receiver.
Sorry this is not the easy fix you were hoping for but I hope that it's been of some assistance.
1st web address. Supplies and excellent general aerial advice.
http://www.aerialsandtv.com/ampsandsplitters.html
2nd address. List of known incompatible equipment. Not really of use to you but at least shows you're not alone...
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Oct 09, 2009 | Televison & Video
How do i retune my samsung tv,now that all freeview tvs had to be retuned the other day. please tell me wat to do via teh remote control
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Oct 02, 2009 | Samsung LE32A457 32 in. LCD TV
Loss of BBC channels
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Philips TV Tuner Video Capture PCI Card -...
How do I retune my goodmans television for
Oct 01, 2009 | Goodmans W280NS Television
I NEED TO RETUNE THE FREEVIEW ON MY DUAL DDLCD1905 TV
If you havent already. Select DTV from the source menu.
then press the DVB button on the remote and choose system setting.
Select First Time Installation to reset all DTV channels
Sep 30, 2009 | Televison & Video
No remote for Swisstec T.V.
Hi rhami,
The only brand of universal remote I know of that has a code for Swisstec brand TVs is the Integra - the code is 0880.
The other option is to order a replacement remote for your model TV. http://www.amazon.co.uk carries remotes for a wide variety of Swisstec TVs (note that www.amazon.com does *not* offer these since Swisstec is British).
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Televison & Video
Televison & Video Logo
412 people viewed this question
Top Televison & Video Experts
Electro Med Services...
