Question about KitchenAid Food Processors
How do I remove a stuck disk stem ? - KitchenAid Food Processors
    Problem Solver:
  • 17 Answers
Buy a new processor and pack up old onein new box and return it... I have same prob... and it warranty but it costs $40 to ship!
Posted on Dec 22, 2009
The stem on my food processor is broken. Help to remove old part
Hi-I have a DLC-7, it looks a lot like yours. On my machine the stem is removed by pulling straight up. It is held only by the friction of a knurled section of the shaft, no threads or other fasteners. You could grip it lightly sideways with a pliers or vise-grips and then use hammer head to tap upwards on the side of the pliers. Squeeze the shaft firmly enough to grip it adequately, but not so hard as to crush it.
May 07, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
My disc stem is stuck and will not come out.
Without careful use and care, there is a possibility that the disc stem can become fused with the motor shaft. If excess pressure is being applied to the slicing or shredding disc, this can cause immense friction and cause the plastic disc stem to "weld" onto the motor base itself.
I would suggest calling Kitchenaid Customer Service to see what options are available.
Their toll-free number is: 1-800-541-6390.
Jun 06, 2009 | KitchenAid KFP740 Food Processor
Disc stem stuck...can't pull it off.
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
Apr 13, 2009 | KitchenAid KFP750 Food Processor
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
I am unable to remove the disc stem
There is no mechanism to lock the stem onto the base of the KFP750. It's just held on by gravity, so you're not missing anything simple!
It's possible that the soap dust got in there and glued in on. Take a blow dryer or very hot rag (use tongs!) to the stem to see if you can soften the soap, then pull up the stem.
Dec 26, 2008 | KitchenAid KFP750 Food Processor
I have ordered a replacement stem for my DLC-7, the stationary stem that covers the motor shaft. I'm not sure how to remove the one currently on the unit.
Remove the pusher sleeve and lid from the work bowl first, then slide the work bowl out of the locked position. At this point, the stem should be exposed.
Nov 05, 2008 | Cuisinart DLC-5 Food Processor
The disk stem is stuck
We had the same problem! I was bending a 18" pry bar and couldn't move it! Finally I tapped the spindle LIGHTLY and it broke loose and have had no more problems. I even bought $80 worth of replacement parts and did'nt use them. The serivce center sold me the parts but the Tech refused to talk me thru installing them.
Jan 03, 2008 | KitchenAid Professional KFP770 Food...
Disc stem stuck
If you mean the post which the cutter thing connects to I have the same problem. I got out my jar of vaseling and smeared vaseline   in the hole after I pried the pole or disk out of the opening with a flat head screwdriver
a bit better   at least it comes out. Now if they would only make the post a tiny bit smaller at the top so the container comes off without a lot of effort,... Mine takes the post with it now that I have put the vaseline on it. good luck
Oct 20, 2007 | KitchenAid KFP740 Food Processor
Food Processors Logo
306 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Shehu Pro
Shehu Pro
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
