Question about Onkyo TX-SR605 Receiver
Every time I try to turn on my onkyo receiver it turns off instantly
  • casey184 Oct 03, 2009
    yeah I tried all the wires and they are all correct
  • 691 Answers
The reason why the receiver probably keep turning off is that the systems come with overload protector to keep one from burning or short the systems out so it shut its self off. make sure you have the speaker wires is connected properly, its very important that you do although the receiver has 0% tolerance when it come to speakers hook up. positive from speaker to positive connector behind reciever; same as negative. double check all speakers wires. repost if that not an issue
Posted on Oct 03, 2009
My Onkyo TX NR609 is not coming on and immediately shuts off and is progressively getting worse it is hooked to a harmony smart hub
Hi Liz, I am sorry about your issue. Please remove the HDMI cable from the receiver that is connected to the TV as a test. Check and see if the receiver stays on. If it does not the receiver would need to be serviced. Thank you, Onkyo USA
Oct 29, 2016 | Onkyo Audio Players & Recorders
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
I have an Onkyo AV Receiver HT-R500 and when I turn it on, it turns on and in less than one second it turns back to standby. What could be wrong?.
Try disconnecting all the speakers and see if it does the same thing. If it doesn't, connect speakers again one at a time to find out which one of them is doing it. Make sure the speakers rating match the output of the amp.
Jun 16, 2011 | Onkyo HTR500 Receiver
When I turn on my Onkyo DTR7 receiver, I donot get any sound at the speakers. Normally there is a click, when I turn it on, but I no longer hear that sound. occassionally it will work, if I turn it on...
You must re-seat the HDMI board on and try. sometimes the connections come loose and causes the connection to the Relay trigger not to work.
Feb 09, 2011 | Onkyo DTR7 Receiver
When power button turned on, receiver powers up
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
May 10, 2010 | Onkyo TX-SR500 Receiver
Hi, after i turn the power on and then press the stand-by button, it clicks off to stand-by mode instantly. This is an Onkyo TX-SR500
This indicates that the system is going into protect mode. First disconnect all speaker wires (with the power cable disconnected). Then turn the unit on and see if it sill shuts aff ofter a few seconds. If it does not, then you have a problem with the speakers or speaker wires. inspect the wires at both ends for frayed strands that may touch. If that all lookd good, plu the speakers in, one at a time, until the problem reappears. Be sure to turn the sytem off before plugging in any speaker just to prevent any accidental short which could be catastrophic. If the system goes into protect mode with all speakers disconnected, you probably have a shorted output transistor.
Apr 05, 2010 | Onkyo TX-SR500 Receiver
Onkyo TX-SR702 remote problem
So what you're saying is you think the receiver is broken because the remote won't turn it on.
Try fresh batteries or another remote that can be programmed for the Onkyo and get back to us.
Apr 12, 2009 | Onkyo TX-SR702 Receiver
Video thru Onkyo TX-RS606 is only black&white
are you using HDMI cables or component. First I would try unplugging the composite and component video cables while the receiver is off. Plug them back in and turn it back on. If that does'nt work try setting the receiver to factory default and redo the settings. You can find how to reset to default in your user manual.
Oct 24, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR500 5.1 Receiver Last night
1-disconnect subwoofer first and test-and then disconnect surround speakers-and front speaker after-and later center speaker.ever time you disconnect you check the operation until you find the bad one(or two)which make the problem change its cable first and then change speaker itself.if all above failed contact the service center.
Jul 04, 2008 | Onkyo Audio Players & Recorders
Onkyo receiver problems
All speakers and lines OK?  Sorry for basic approach!!  Protection is supposed to work when speaker outputs are loaded under recommended Z. speaker Z is a setting too ... along with several other paramenters.  Also, re the "last return" ...  Maybe the back surround speakers were turned off in settings?  Again, apologies if you've tried all this basic stuff.  I've just bought one of these amps and have probs with the FM tuner not tuning anything.  Mmmm. Back to the shop??   Cheers, Chris
Oct 03, 2007 | Onkyo TX-SR503 Receiver
Onkyo TX-SR605 Receiver Logo
330 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
