Question about HP OfficeJet 7410 All-In-One InkJet Printer
Unit will not power up. hp invent logo on screen. tried all combos of unplugging with # and 3 or # and 6 keys to reset. is it fried?
  • thegolfmeist Oct 05, 2009
    Hi. What do you mean by input and output doors? My system is wireless so the only wire to the printer is the power cord. I tried everything and still cannot power the unit up. Why is the screen active with the "HP Invent" logo even when the power light is off?
  • 708 Answers
Plug something else into the outlet to make sure the outlet is good.
IF it is
you could have a bad power cord
I had a 7410 a few years ago and it did this and it was a bad board internally. I ended up junking it.
IF you are interested I replaced mine with a canon MP530 and it has worked beautifully for me. I reccomend canon printers.
Posted on Oct 06, 2009
  • Chris Yelton Oct 19, 2009
    As I mentioned in another post mine had a bad board so it was fried. Where you able to locate a new power cord to se if it was bad. IT is a possibility, however if there are no frays or kinks in your power cord it should be fine.
    Typically printers cost more to fix than just replace. I would recomend just replacing it.
    Brigadier General:
  • HP Master
  • 3,614 Answers
1.
Disconnect the power cord from the wall outlet.
2.
Disconnect the printer data cable from the printer (if applicable).
3.
Disconnect the power cord from the printer.
4.
Wait 30 seconds, and then reconnect the power cord to the printer.
NOTE: Make sure that the Input and Output doors are open. A few printers will not turn on if the doors are closed.
5.
Reconnect the power cord directly into a working wall outlet.
NOTE: If the power cord is plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
6.
If the printer still does not turn on, wait 30 seconds and press the Power button again.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Hope this helps
Posted on Oct 05, 2009
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
Mar 01, 2011 | Office Equipment & Supplies
My HP Officejet 7410 Unit is powered and the HP Invent logo is displayed on the screen with the progress bar moving at the bottom, but the power button is not lit and none of the other printer functions...
I will advice you reset the printer, follow the steps below to reset the printer,
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold ?# and 6? keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
If that did not fix the problem, try this,
  1. Unplug the power cable from printer while the printer is powered on.
  2. Press and hold OK and HELP buttons while plugging in the power cord. Wait for the screen to go black or blank before releasing the keys.
  3. Just turn on the printer and configure your printer new.
The problem should be fix with this.
Take care.
Sep 14, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
All the lights are flashing and it says to Reset power. I disconnect the power cord and reconnect. The system looks like it is resetting and then the same flashing lights appear and it again says to Reset...
Hi Joe,
Lets try 2 steps:
1st approach:
1. With the printer “ON” unplug the power cord form the printer.
2. With the printer now unplugged, press and hold “# and 6′ keys in the printer..
3. While still holding these keys down, plug the power cord back.
2nd approach:
1. Unplug the power cord
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
(repeat 3 times)
If none of these to approaches work, I’m afraid the failure is “fatal” as the main circuit board might be fried L
Regards,
Ed
Nov 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer won't turn on
Well it just needs some good old TLC it just may need to be repaired if the reset did not work if its under warrenty hp will replace it give them a call you be glad you did.
Rulds2008
Aug 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Cartrage stop moving and all power ,copy ,scan and fax buttons are lightening
It might be a hardware issue however u can try the following basic troubleshooting steps .
Unplug the power cord from the back of the unit . try to move teh carriage manually .
perform a reset as well .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6
Thanks
May 27, 2008 | HP Officejet 5610 All-In-One InkJet...
Incorrect Cartridge
As you mentioned you have already done a reset on the printer , may i know how u have done it ? In case u did a power reset like > turning off the printer and turning it on , you can also try the following steps as well .
5
6
7
thanks
Apr 22, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Can not print color on hp officejet 7110
it might be a hardware issue with the printer however we still can try the following stes to reset the printer.
5
6
7
Thanks
Mar 07, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Hp photosmart 2610
HI,
u can try to reset the printer.
5
6
7
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
Mar 03, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
