Question about Initial Mobile DVD Player with 10.2" Widescreen Overhead Flip-Down LCD Monitor - IDM-FD10 Car Video Player
Initial DVD - lamps won't go off
The lamp lights on my Initial IDM FD10 Overhead DVD player won't turn off. Also, every time I open or close the doors while the DVD is on and tuned in on the radio, it makes a horrible noise. Are these problems with the wiring? Or, general defects of this cheap DVD player.
0 characters
1 Points
How do I get a dvd out? the eject button wont eject the disc..
Ah! This is an easy fix! All you need is a bigger sized paperclip or something of that sort. You bend out one piece of the paperclip (a 90? angle) and push the paperclip Straight in the little tiny hole you can see on the disc door or next to the door. It will manually turn the gears to roll out the door.
Jan 26, 2015 | Audiovox ADV45 - 12.1 LCD Overhead Monitor...
Using without parking break
Hi James,
Page 27 of the installation manual ( shows a connection to the parking brake light circuit. It is the Light Green wire labeled "PRK SW" shown below.
If it is connected the way it is drawn, the PRK SW wire is connected between the lamp and the switch that opens and closes depending on the position of the parking brake (set or not). 12 volts is always present from the battery to the top of the lamp. It passes thru the filament to the wire that goes the top of the parking brake switch. So, when the brake is OFF or disengaged, the lamp is off and 12 volts is present on the PRK SW wire to your Kenwood GPS. When you set the parking brake, the ground (symbol is the funny slanted lines under a horizontal line) just under the brake switch passes through the switch and changes voltage at the PRK SW to "ground" or 0 volts. When this happens, the ground on one side of the lamp with 12 volts on the other side of the lamp - make is turn on.
So, what does this mean? Simply tie the PRK SW wire to any grounded metal and the Kenwood will think the parking brake is always set - for as long as it is tied to ground. You can check it with a simple voltmeter to be sure. Set the meter to 12 volts or more, touch black lead to ground & the red lead to the PRK SW wire. Kenwood should only work when at 0 volts (brake set). Release the brake - meter shows 12 volts & the Kenwood shuts off.
I hope this helps & Good luck!
Apr 09, 2014 | Kenwood DNX570HD
How to wire domelight in rosen overhead dvd player
put dvd purple wire to the car gray wire your traverse has positive trigger. Hope that works , switch has to go to positive on dome switch . Please post back if that works.
Jun 27, 2012 | Rosen G10 Car DVD Player
I need installation directions for my overhead dvd player 9.5. I want to put it inot my 2003 gmc Envoy
Installation directions for an overhead DVD? If you have never done an overhead DVD installation, I recommend that you have it professionally installed.
Sep 22, 2010 | Insignia Mobile DVD Player with 9.5"...
Is it possible to install an overhead DVD player (example Clarion) in a Buick Enclave 2010
Sure! why not? It is commonly to install clarion overhead dvd player in cars today. Recently I bought a clarion overhead dvd player for my chrysler. It brings a lot of fun!! I just love it. Hope that could help. [url=""]clarion car DVD player[/url]
Apr 13, 2010 | Clarion OHM1075VD Car DVD Player
No power
Check the fuse for it if you haven’t yet.
May 22, 2009 | Rosen CS700DVD Car Show 7.0 7 Inch...
Pyle dvd player dome light
You need a third wire
The 12V Red need to go to a constant positive (battery) the yelly needs to go to the positive from the two wires, and the ground should go to the ground for the two wires
Feb 05, 2009 | Pyle Car Video Players
DVDS stuck in overhead DVD player
the motor will not be strong enough to eject. you can try the emergency eject hole with a paper clip . just push straight in and the gears will began to turn so push straight in a couple of times and it should began to eject.
Dec 13, 2008 | Jensen 8.5'' Overhead DVD Player Package...
Jensen MVB85 A8.5 dvd player
Problem: All DVDs would not play in Jensen MVB85A overhead 8.5 DVD player. Error code: "Incorrect Region Code"
1. Use the remote to power on DVD player
2. Ensure there are NO DVDs in the drive
3. When you see the DVD logo screen, press 9653 on the remote
4. A hidden menu will open stating the region code. My region code was set to 0 and my I was receiving the error.
5. Press the "OK" button to change the Region Code to "1".
Once the region code was set to 1 all DVDs were playing.
Key words: Jensen Audiovox MVB85 incorrect region code
Nov 13, 2007 | Jensen 8.5'' Overhead DVD Player Package...
Skipping problem
The problem is likely due to the "door closed" switch not engaging properly. To get better engagement, superglue a tiny piece of a credit card to the tab located in the lower lh corner near the DVD when the player is open. This is opposite of a portrusion that presses the tab down whne the unit is closed. The unit is restarting because it thiks it is being opened due to the switch not sidengaging from time to time.
May 06, 2007 | Audiovox D1708ES Car DVD Player
Car Video Players Logo
64 people viewed this question
Top Initial Car Video Players Experts
xxxxxx xxx
Are you an Initial Car Video Player Expert? Answer questions, earn points and help others
