Question about Frigidaire GLTF2940ES Front Load Washer
Affinity washer My washer door closes and when i turn it on i get a dr error and it buzzes as if there is something blocking the door but there is not. please help me
  • 1 more comment
  • 2boys_mommy Jan 09, 2008
    Please help ! I Have a frigidaire front loader and it starts showing "dr" when I try to start it.
  • Anonymous Jan 19, 2008
    I have the same problem sometimes. I cannot figure out why it is a problems sometimes and not others. It seems to happen when I have a larger load, but nothing is touching the door and it closes easily. Owners manual says okay to fill to top without compressing.
  • Debidud Mar 23, 2009
    I keep getting dr error. The door is definitely shut. I've even held the door shut with pressure and I still get the error. It worked fine yesterday. There is nothing in the way and it is not a large load.
  • 249 Answers
I think that means faulty door electric lock
Posted on Dec 21, 2007
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have Frigidaire Affinity ATF7000EGO washer. i just replaced the door striker but now everytime it goes to start cycle starts buzzing and reads DR....
Double check that the mechanism is fitted correctly and all wires are attached as off the top of my head that is the error code for the door not sealed properly. Hope this helps.
Nov 17, 2013 | Washing Machines
Error code DR comes up on my Frigidaire Affinity and won't keep running
It is telling you there is something wrong with the door lock assembly. You will probably have to replace it, but check it first for a broken wire or some other problem that you can fix.
Here is a link to the part if you need it.
Here is a link to a service manual for your machine that will take you through the testing and repair process.
Oct 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
My affinity washer will not close to start a cycle. the buzzer goes off and i get the code "dr" but it seems to close fine
Have a service technician test the sensor in the door jam that senses when the door is closed (this is signaled by the electronic lock).
Dec 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
It means the door isn't shut all of the way.
Aug 17, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
