Question about Car Audio & Video
I dont know where the ecu chip on my honda civic is located its a 1995 i am trying to fitt A MUGEN ***ECU CHIP P30 VTEC OBD1 CIVIC CRX B16a2 92-95
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
In most older honda civics the computer is located in the passenger kick panel. if you remove the bottom right side panel below the glove box you should see it. if not, it will be in the passenger floor board under the carpet.
http://www.qcwo.com/otherdeal/images/honda_ecu_location.jpg
hope this helps
Posted on Oct 06, 2009
1998 honda accord removal
you may have to change the ecu , to match the vtec, because i dont think you can reprogram those ecu units.
May 12, 2014 | 1998 Honda Accord
Engine & ECU swap: '92 Integra OBD1 Vtec B16A-A/T,some dash functions don't work now.
wow and engine swap on fixya, are you kidding?????
why not join a real honda forum.?
first off: get the FSM for both cars. that be day 1.
then ask on a real forum under the swaps sections.
what to expect, yes, do expect many things to not work.
first google hit, am i blessed with luck?
http://www.civicforums.com/forums/15-buy-sell-trade/333878-engine-swap-specifications.html
try there.
Jan 03, 2014 | 1994 Honda Civic Del Sol
H22a vtec 1994 model
some models wiring is not compatable with others even though they look the same..did you cross reference anything or not...
Feb 10, 2013 | Cars & Trucks
The 1999-2000 Model Honda Civic uses an OBD2B connector for the ecu. I am changing my ecu to a programmable OBD1 PO6 or P28 ecu. Therefore i would need a jumper harness from OBD2B to OBD1. I already have...
The reason you can't find the connector you want = it's illegal to replace the OBD2 PCM with a OBD1 controller for any vehicle registered for the street. This is a felony on the Federal level and also several States. If you are only using the car for the track, it's ok. You may try a raceing supplier like Summit, etc. to find one.
May 11, 2011 | 1999 Honda Civic
What other engine will fit a 97 civic ex?
The 96-98 Civic EX came with an OBD2A D16Y8 engine. That is the only engine that will go in as a direct replacement with your current engine ECU. It's an SOHC VTEC engine that has two extra connections not found on the other 96-98 Civic engines - a VTEC solenoid and a special oil sensor used to determine if VTEC engagement is possible. If you swap in an older Civic engine (92-95 generation) you'll have to convert the car to OBD1 (requires a special adapter hardness) and run the ECU that goes with whatever engine you use. This will break functionality of your OBD2 diagnostics port, and depending on which state you live in will cause you to fail emissions checks. If you install a D16Y8 engine from a 99-00 Civic EX, you will have to swap the intake and exhaust manifolds from your old engine to the new engine, and you will be able to continue to run your existing OBD2A wiring and ECU. The 99-00 Civic EX engines have additional sensors, since those engines are OBD2B. The easiest fix would be to find a SOHC VTEC D16Y8 from a 96-98 Civic EX, as it would be a direct plug and play replacement.
Apr 16, 2010 | 1997 Honda Civic
Vtec not working
u need to up geade ur ecu or get the car remapped the ecu is not for that engine so hens the magament lite is on best of luck
Mar 07, 2009 | 1996 Honda Civic
I have 1991 civic shell, swap to 1994 del so jdm ingine,
Go to honda-tech.com Register and you can download the manual that matches your engine. Chances are that you do not need all ten wires. Russ (camieng on eBay)
Jul 29, 2008 | 1991 Honda Civic
Honda ecu
ignorant put it in the c slots inside of the dotted white lines
Jun 04, 2008 | 1994 Honda Civic
Car Audio & Video Logo
125 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
