Question about Microsoft Xbox 360 Console
I bought a cod5 for xbox 360 yesertday so i came home put it in and it said you must clean disc then i blew into my xbox360 and it started working but now it keeps doing the same thing over and over
  • Rod Sims
    Rod Sims May 11, 2010
    does it happen with HALO 3 also?
  • 43 Answers
The disk or disk drive are most likely damaged
Posted on Oct 03, 2009
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
When I put may kinect game in the xbox it says the disc is unreadable, then it says to clean disc with a soft cloth and restart the console. I did that several times and it still wont work. What should i...
If the disc has a lot of scratches then it is the fault of the disc. The Xbox360 is known to scratch up discs so you can either buy a new copy of the game or follow the video in the link below. http://www.ehow.com/video_4774663_repair-xbox-360-game-discs.html
If the disc is fine then the laser of the Xbox360 that reads the discs may have issues. If that is the case then you will need to send it to Microsoft to repair for a fee or find someone who knows how to take apart and fix a 360.
Jun 20, 2011 | Microsoft Xbox 360 Console
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
I bought cod5 yesterday for xbox360 so i came home put it in went to multiplayer and it said you must clean disc so then i blew into the 360 and it started working but today it has been doing it over and...
Try any other game and see if you get the message.
If you do, then it is time to get xbox repaired. Find a local computer tech nearby and they will be able to get you a new DVD reader and install.
Oct 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 sounds ill
Strangely enough inside any of those game boxes is a simple DVD reader driver like for a PC.
It can be replaced.
First I would try cleaning it with a spray air electronic cleaner or any sort of DVD reader cleaner.
Dust will accumulate in them even with the little door that covers it when closed.
If that's not the case, the sensor can also be cleaned with alcohol and a q-tip if you take off the case or the motor may be going bad ont he DVD drive itself.
Start with the basics.
Jul 23, 2009 | Microsoft Xbox 360 Console
Xbox will not read any game or dvd
It sounds like your DVD drive has failed, this is fairly common. There is a good chance it is still under warranty from microsoft. Give them a call at:
800-4-My-Xbox
If it is not under warranty you can replace the dvd drive itself, google xbox 360 replacement parts. It's not too difficult if you are technically inclined.
Jun 25, 2009 | Microsoft Xbox 360 Console
Problem with xbox360
Try and open the dvd drive and clean the laser and the cd spinning motor with qtips and rubbing alcohol and see if that works. that is the most probable cause.
alex
Jul 08, 2008 | Microsoft Xbox 360 Console
Help Me!
the disc is broken look at it closey for scartches are look for a big ring around the disc. then clean the disc.
Jun 19, 2008 | Microsoft Xbox 360 Console
Xbox360 game will not read
If your xbox is modded try a different brand of disc.
Obviously try and clean the disc itself.
Else your dvd drive is faulty and needs to be replaced
Mar 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
